Tire Deviation Question.
Ok I'm no stranger when it comes to plus sizing and the lot, but upon looking at the Master Tire Guide, I remembered that the Euro R's have 225/45 17 stock correct. According the guide that would be a great deviation. So why can they run such a smaller size in diameter. Is it because of the different motor? or diff gearing ratio? Help me out anyone? Thanks for the input.
Originally Posted by ILoveMyHonda
So if I wanted to replace my tires with 225/45 's it should be ok?
Or does that mean I will have slight speeedometer discrepancies.
JDM EuroR
3.266/2.130/1.517/1.147/0.921/0.738, 4.764 final
TSX 6MT
3.267/1.880/1.355/1.028/0.825/0.659, 4.760 final
I love to have the 2nd gear ratio from the JDM EuroR to eliminate the 1-2 bog. Wonder if I can just buy the 2nd gear ratio from Japan.
Originally Posted by vwong
The EuroR comes stock 215/45/17 tires and their gearings are slightly different from the TSX 6MT. Here are the gear ratios between the two.
JDM EuroR
TSX 6MT
JDM EuroR
TSX 6MT
Yeah those stats are interesting, I wonder why those chose to gear the TSX that way?
Oh and Lanny do you have some pics I'd like to see what that sidewall looks like, plus Im only lowered Fr: 1.1 Rr: 0.75
I think they did that cause they want the fastest 0-60 times possible and you can't do that if you have to shift to third before hitting 60. At least that was the theory for the 6spd Celica. That thing had horrible gearing. SER Spec-V had bad gearing too.
.......Lanny do you have some pics I'd like to see what that sidewall looks like, plus Im only lowered Fr: 1.1 Rr: 0.75
Originally Posted by LannyM
225/45/17 Yokohama ES100s on '05 RSX-S rims, 17 x 7 45 offset, lowered 2.0f and 1.7r with Tein FLEX......
hey thanks for the pics, and how large they are.....really helped me see the gap close up, like if I was really there. Hmmm maybe I should reconsider that tire size, it might make my wheel gap back to looking stock again......
since you have a 2.0 drop in the front and i only have a 1.1 drop...oh and did the extra 10 mm of offset make much of a difference as being flush with the fender?
When I had the factory 215/50/17s with that drop, the tires looked well inside the wheelwell-from the rear looking down the side it didn't look like it had tires
. So I kinda wanted to move them out a little. There really wasn't even a finger gap before.....
CostcoFanAUS
Sep 18, 2015 06:05 AM
alan_rich
Sep 7, 2015 11:08 PM
