Spring Installation, Top Hats?
Old 03-11-2008, 07:45 PM
ASM 3G TL Type-S
GTSX-05's Avatar
Hey guys,
Anyway spring being right around the corner, I am getting ready to get my shock and spring combo installed, quick question if I use my OEM top hats, will there be any issues in squeaking or clunking? or would it be a direct swap onto the new suspension. Do you guys recommend me buying new top hats for the install, or re-using my vehicles OEM top hats?
Picture just for fun;
Anybody know how much a set of new top hats would set me back? is it recommended?
Old 03-11-2008, 10:04 PM
bo0sty's Avatar
i think heel toe auto sells they i think its ~130 for all corners i think, i dont think there necessary, you should probably spend the money on a camber kit instead
Old 03-11-2008, 10:54 PM
cali4tsx's Avatar
I using my oem hats on my new suspension... no squeaking at all.
heeltoeauto have the hats for a bit over $100
Old 03-11-2008, 11:01 PM
JayRoam's Avatar
used my oem's too. no squeaking
Old 03-12-2008, 10:52 PM
csun2004's Avatar
Search
Old 03-12-2008, 11:04 PM
fury's Avatar
nice
post pics after install
hoping to get my HPs soon as well...
Old 03-13-2008, 07:01 AM
ASM 3G TL Type-S
GTSX-05's Avatar
Originally Posted by csun2004
Search
Search what? I am specifically asking if there’s going to be any issues with squeaking and clunking, I’ve read all the older threads.
Old 03-13-2008, 07:06 AM
ASM 3G TL Type-S
GTSX-05's Avatar
Originally Posted by fury
nice
Thanks fury, its a real *itch not have these in yet, I am waiting for weather to clear up here in T.O. so I can enjoy my drop and ride.
Old 03-13-2008, 10:19 AM
LukeaTron's Avatar
Having gone through this a number of times, I'd recommend buying another set of top hats and having the struts fully assembled before you start working on your car. Getting the springs on is easily the bitchiest part of the job (unless you break something) and having it out of the way before your car is half taken apart is a major stress reducer.
The other advantage is that if you ever need to swap your old suspension back in, it's all there and ready to go. You can probably change all the struts out in about 4 hours if you know what you're doing and you have everything ready.
If it's your first time doing this, make sure you've got two days where you won't need to move your car and another ride available in case something breaks.
Old 03-31-2008, 01:11 PM
ANTZ
ANTZ TSX's Avatar
Hey GTSX-05 where did you get your springs? Do you know anywhere around I can get some with good price?
Can't wait to see your pics!!
Old 03-31-2008, 02:47 PM
Former Sponsor
MrHeeltoe's Avatar
http://www.heeltoeauto.com/Honda-Gen...X-pr-4813.html
Here they are. Use "acurazinerocks" coupon for 5% of anything on the site (order subtotal minimum $100).
Marcus
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
jmoney2001
08-12-2019 06:23 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
SinCityTLX
63
03-23-2016 02:13 PM
Quick Reply: Spring Installation, Top Hats?
