lowered tsx tire choice
Old 12-28-2014 | 04:43 PM
Benben's Avatar
4th Gear
i just got a set of tl rims (2004) I a lowered with koni yellow and neuspeed race spring(2-2.5 inch) I was wondering wich tire size i should get. 225-45 would rub? anybody with similar set up?
Old 12-28-2014 | 07:50 PM
tsxykid105's Avatar
youll have remove or trim the fender liner in the front and bend the tabs up at least. add a little camber in the rear. id go with a 215/40 tire. i have 18x8.5 et38 with 215/40 for a tiny bit of stretch and all fenders rolled flat. you should be fine either way.
Old 12-28-2014 | 08:01 PM
Benben's Avatar
4th Gear
so you think i absolutely have to roll the front fenders? . I already have a rear camber kit so the rear should not be a problem
Old 12-28-2014 | 09:02 PM
tsxykid105's Avatar
since your 2-2.5" lowered you will. my stock tsx wheels would rub on unturns at that height and the tl wheels are 45offset. if it were me id roll all my fenders and run 215/40 or 225/40. i try to have the least amount of camber i can. if your tucking tire in the front or rear then id do what i said. im tucking and i would say im 2.5'' lowered.
Old 12-28-2014 | 09:18 PM
Benben's Avatar
4th Gear
Now i have stock wheels and stock tire size and no rubbing at all. I was hoping to run 225/45 with tl wheels without doing nothing to the fenders. I guess i will have to roll them
Old 12-28-2014 | 09:23 PM
tsxykid105's Avatar
put them on. you can camber the rear i just dont like tons of camber and the front you might get away with trimming the fender liner and pushing up the tabs but i think youll rub on turns and full lock.
Old 02-15-2015 | 09:39 AM
BROlando's Avatar
What? TL wheels fit just fine with no fender mods. I left my camber where it fell when I lowered it.
I ended up with like -0.5 front and -2.x rear. Neither of those is going to cause tire wear. I could dial out the rear camber to -1.x and still not have to roll fenders.
I use 225/45/17 tires. I have 2 sets of wheels/tires.
TL-S 17X8 +45 with 225/45/17 Michelin Pilot SS
TL base 17x8 +45 with 225/45/17 Continental Winter Contact.
BROlando's Avatar
^to add...I'm lowered about 1.5-2" on Tein SA coilovers
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
gqdabien
09-08-2015 11:41 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: lowered tsx tire choice
