Hm..WTF Height difference on left and right??
hi, i just recently installed 110-155 on my tsx..installed it through a bodyshop
but the problem is front left side's wheel gap is about...half inch bigger than the
right one....wtf???
went back to bodyshop, and they re-installed spring on left side...didn't fix the
problem...and now they're saying spring is defect..
do you guys have aany idea what might be causing this prob??
if you know, plz lemme know!!
thx for reading guys.
right one....wtf???
There is usually slight height differences as the weight of the car is not evenly distributed left and right. If you pop the hood open, you will notice the engine is positioned closer to the passenger side.
Originally Posted by umhaha84
so..it's normal for a dropped car to have slight difference in heights??
Originally Posted by aaronng
You won't believe it, but half the world away here in Australia, we Accord Euro owners noticed the same thing. The left side is higher by 1 cm (0.4 inch)
Originally Posted by JTso
I believe it and see it all the time on other cars as well. Additionally, the rear right camber on the TSX is usually more negative than the right side. Sometimes it's out of spec from the factory.
why is that though?
I'd think it's intentional, along the lines of positioning the engine closer to the passenger side. The driver acts as counterweight to balance the engine. If you think about it, if you try to adjust your suspension to even it out without a person being in the car, once you get in the front left will be lower than the front right. That could definitely cause problems driving.
Originally Posted by kaikai114
why is that though?
Originally Posted by Alin10123
Yea, what Yui said. They are assuming that most of the time you are in the car by yourself. So instead of having it misbalanced the whole time they figure they would try to balance it out a little.
What if the car is right hand drive? The engine would still be on the same side. right?
I have the a-specs put on and mine is the opposite because the right side has a 1/4" more in the wheel gap. Meaning the car is leaning slightly to the left and I definitely notice it when looking at the car from the rear. It's really annoying me and I'm thinking of taking it to the dealership for another look. The rear wheel gap is identical. Can some of you stock folks measure your front wheel gap and provide some numbers? I used a caliper and measure exactly a 1/4" difference between the left and right wheel gap. Thanks in advance!
billmcd
ILX
Oct 17, 2016 03:33 PM
