HELP- Tein coilover install problem
Old Mar 20, 2005 | 08:00 AM
  #41
Delmiroc's Avatar
Guys my TEIN basic don't look like like that
I looked everywhere on my suspension after my Tein Basic installed and I don't think they have this.. could I be wrong? I don't hear or feel anything wrong with my suspension.. drives good....
Old Mar 20, 2005 | 09:37 AM
  #42
JTso's Avatar
Read post #34 above. You need to reuse certain original hardware if they didn't include new ones. The Tein Basic didn't include the top mount either, and you reused the stock one, right?
Old Mar 20, 2005 | 10:16 AM
  #43
LannyM's Avatar
Hondaholic
Look again, it should be there. Underneath the dust cover.
If you don't have the bumpstop, you could do some damage to the struts if you hit a really big bump. Other than that, you wouldn't notice that it wasn't installed........
Old Mar 20, 2005 | 11:27 AM
  #44
Delmiroc's Avatar
THank you guys.. I will check.. and maybe post some pictures.. thanks again
Old Mar 20, 2005 | 11:38 AM
  #45
itrhybrid's Avatar
Registered Schmegistered
That bumpstop is the stock one. My SS Coilovers came with new white bumpstops. No need to use these ones.
I don't recall, but are basics coilovers, or just springs?
James
Old Mar 20, 2005 | 12:16 PM
  #46
LannyM's Avatar
Hondaholic
According to the directions, Basics and SSs come with new bumpstops. Hopefully the installer put them in.
This is where you could look for it:
Can't see it with the dust cover pulled down.....
Push up the dust cover; still can't see it.....
Reach up under the dust cover and pull it down.....
Old Mar 20, 2005 | 12:32 PM
  #47
JTso's Avatar
Nice Flex LannyM!
Old Mar 20, 2005 | 04:05 PM
  #48
Delmiroc's Avatar
that coilover looks HOT
thanks for the post LannyM !!!
Old Mar 20, 2005 | 08:23 PM
  #49
xizor's Avatar
Bye TSX, hello domestic?
when are those babies going in!
Old Mar 20, 2005 | 09:27 PM
  #50
LannyM's Avatar
Hondaholic
They went in this afternoon.
It's wet and near freezing right now, and I think it's going to snow tomorrow, so I can't really try them out yet. Tuesday looks nice though, so look for a review and maybe a couple of pics.......
Old Apr 3, 2005 | 08:09 PM
  #51
xizor's Avatar
Installed my Tein SS today and thankfully didn't have this problem. If you follow the instructions closely you should be fine.
Its easy to miss the thick washers, they're pushed into the stock bumpstops on the fronts. you need to pull them out and put them below the black washers. the thick washers will fit perfectly into the grove of the Tein shock. Make sure its not upside down, I believe in the front the rounded side goes down, and on the rear the rounded side is up.
I sprayed everything with silicone lubricant as I was assembling it and haven't had any noises, clunking, or squeeking.
Old Apr 4, 2005 | 02:44 AM
  #52
TypeSblkura's Avatar
JAPAN
the same shit happened to my cl...turned out that i didnt use a washer that was on my oem setup...remember to use all your oem materials!
cycdaniel
Dec 17, 2019 10:58 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
james357
Feb 13, 2016 02:37 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
nanos
Nov 12, 2015 08:41 PM
