Help I need shocks (Miami)
Eibach Sportline Kit installed and factory shocks are blown, i need sport shocks and Alignment anyone know of good shocks and a shock in South Florida that will install the shocks.
Got Phó?
Originally Posted by xizor
koni's are the only aftermarket shock and they're $600, not much more than a set of Tein Basics
無限 本田 CL9
but yea, xizor is right.. $700 should get you a set of tein basics.. just dump those silly springs that ruined your stock shocks =) with a set of coilovers, at least you'll know the spring rate is matched perfectly for the absorbers
A DiRTBAG decal on my
Originally Posted by Zoopa
Does Bilstein make any? How are the Konis?
Bilsteins makes shocks for the TSX, but none are avaialbe in North America. Good luck getting ahold of them
Originally Posted by devitocoke
Coilovers are expensive and i already have the Eibach springs installed.
When you eventually get your shocks installed the entire shock assembly has to be removed so it is not too late to switch
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
4drviper
09-23-2015 07:42 PM
