dropping
Old Sep 25, 2006 | 03:41 AM
smiley405's Avatar
8th Gear
dropping
hey i was wondering what set up do you guys use to drop your car? i was thinking in some tiens but im not so sure.
Old Sep 25, 2006 | 05:43 AM
godfather2's Avatar
Time to Climb
try posting under "tires, wheels, and suspension." anyway, i'm on tein basic coilovers ... nothing fancy, but they get the job done. ride is smooth and uncompromising - unless, of course, you feel liker lowering your car over 1.5" also, you're gonna need a rear camber kit if you drop your tsx
Old Sep 25, 2006 | 08:39 AM
cibs's Avatar
^^ i too am on tein basic coilovers....
i figured no need to spring the extra dough for the SS seeing as I definitely wouldn't be adjusting the dampening very often seeing as you have to remove the rear seatpan and side bolsters to get at the tops of the towers in the rear, and i definitely wouldn't spring for the EDFC... the tein basics are great and i have no complaints so far... it's only SLIGHTLY stiffer than stock, so it makes for a great ride even if your car is full of people..
Old Sep 25, 2006 | 09:31 AM
CCColtsicehockey's Avatar
I am using TEIN Flex Coilovers.
However try the search function
Old Sep 25, 2006 | 09:35 AM
KapVu's Avatar
New to Modding Cars
how low did you drop your car using the tein basics? you said not to go lower than 1.5"? I was hoping to drop it all the way down.
Old Sep 25, 2006 | 12:09 PM
smiley405's Avatar
8th Gear
thanks for all your comments guys so now im on the search for some tien basics.
Old Sep 25, 2006 | 02:45 PM
no more si's Avatar
Old Sep 25, 2006 | 06:43 PM
xizor's Avatar
Bye TSX, hello domestic?
don't get anything except Flex or Buddy Clubs (or something w/ full length adjustment) if you want to slam it
Old Sep 25, 2006 | 10:38 PM
KapVu's Avatar
New to Modding Cars
What I meant was that on the Tein website, it says that the Tein Basic Coilovers are rated to drop the -2.0" in the front and -1.6" in the rear. Is that not possible or not recommended?
Old Sep 25, 2006 | 11:08 PM
xizor's Avatar
that's probably a good drop for the Basics
Old Sep 26, 2006 | 12:16 AM
KapVu's Avatar
New to Modding Cars
would you drop it all the way down with the basics? Would that make the ride even stiffer?
Old Sep 26, 2006 | 01:05 AM
minkl81's Avatar
how about some of these
Old Sep 26, 2006 | 09:24 AM
KapVu's Avatar
New to Modding Cars
too expensive? lol. I like the basics because they're in a good price range and I think i'm getting a good bang for my buck.
What are you guys settings on the basics?
Old Sep 26, 2006 | 11:40 AM
Joeys'TSX's Avatar
I have the same question....does lowering it more than 1 to 1.5 inches make it a lot more stiff?
Old Sep 26, 2006 | 11:41 AM
Excelerate's Avatar
Former Sponsor
The lower range on the Basics for the TSX are -0.5 to -3.3 for the front and -0.6 to -2.4 in the rear.
Old Sep 26, 2006 | 11:46 AM
Joeys'TSX's Avatar
Do you mean lowering range?
Old Sep 26, 2006 | 05:40 PM
KapVu's Avatar
New to Modding Cars
So what if you drop -2 in the front and rear, would that make the ride a lot more stiffer compared to stock?
Secondly, is it safe and recommended to do so for the TSX?
I ask because it seems like everyone is just dropping an inch or so.
Old Sep 26, 2006 | 10:30 PM
xizor's Avatar
yes, basically you're changing the spring preload when you adjust the height on the basics or SS, the preload will affect the spring rate, so if you drop it to the max its not all that comfortable
Old Sep 27, 2006 | 07:11 AM
Joeys'TSX's Avatar
SO I guess the lower you go the stiffer it gets.....ok.
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
