Dampening Firmness, what's your setting?
I Quit
I know it's hard to say what your dampening firmness is because each brand varies. However; what I am interested in more than what "setting" you're at is what you have front vs. rear.
So, is your front stiffer than your rear dampening settings and by how much? I have mine set firmer up front however I want to know the pro's and con's and personal experiences, maybe it should be equal?
Thanks for the opinions.
^^ Wheel load is independent of damping settings. The damping only effects the dynamic motion of the suspension. Spring rate and preload will effect how much weight ends up on the wheels.
You will generally want a higher setting up front since there are a lot of dynamic forces at work on the front wheels of a FWD vehicle. A higher damping setting up front will reduce wheel hop under acceleration and slow down the weight transfer under braking (but not how much weight eventually ends up there). You want the back of the car to lag slightly from the front because it makes the car more stable. The higher the damping rates on the rear, the more snappy the car will feel. For instance if you weave lightly back and forth, the car will respond more briskly. The down side of this that it's much easier to end up with too much weight on the outside tire and cause it to break free inducing oversteer. A lower damping setting in the rear allows the weight to more slowly settle onto the tire. The wheel will still break free under the same lateral G-load but it will transition more smoothly and controllably.
boost owns
Tein SS, 14f/12r. I was running 10f/8r for a long time but over the summer I noticed that I was experiencing slight rubbing at highway speeds (got home from a weekend in Boston and saw shredded tire all over my rear fender). Cranked the dampening firmness up and that problem's gone away. Raise my car? Fat chance...
I have my car on stiff settings all around
From my expereince (Please correct me if im wrong):
The stiffer damping takes away some floatiness over larger bumps so your car wont be crazy bouncing up and down.
stiffer damping reduces the nose diving “phenomena” when you hit the brakes so hard
Also stiffer damping helps preventing the car from bottoming out
You pretty much only see dual adjustability on remote reservoir dampers. I'd hope any one spending $4,000 or more on suspension components has a need for and the know how to adjust them.
I Quit
If anyone has a fancier set up speak up and let me and the rest of us know!
I Quit
Care to elaborate on what you suspension is and ride height? I'm curious! Thanks!
My TSX is lowered on Tein SS
Currently I have the damping stiffness on 2 front and back
In the past the stiffness was on 8 front, and 10 back and I used to scrape on certain streets.
Now that I have the stiffness on 2 all around, I do not scrap on those same roads
So with the stiffer setting every time I hit a bump it feels like a sudden and quick drop with instant and quick rebound back up
However when my car was on soft setting every time I hit a bump it felt like my car was bouncing and bouncing.
Like I said above the stiffer damping takes away some floatiness
I Quit
^^Ksport factory is 12/7 f/r, would that make you set up softer than ksport factory spec? I am not expert on these numbers and their relation to ride quality so if you can elaborate I'd greatly appreciate it!
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
