COMPTECH or PROGRESS?
Old Dec 6, 2005 | 02:45 PM
HaPPy jU1cE's Avatar
which sway bar would be a better choice? comptech or progress...both are 22mm...would it really matter?
Old Dec 6, 2005 | 02:47 PM
curls's Avatar
Someone stole "My Garage"
It's been discussed a LOT here. Run a search and you'll find your options.
Old Dec 6, 2005 | 03:14 PM
amadeus303's Avatar
TSX Sold! Hello STi!
Use the search... the short of it --- if you plan on adding an aftermarket exhaust down the line, get the Progress.
Old Dec 6, 2005 | 03:35 PM
CJams's Avatar
Guinea Pig
Comptech RSB + Comptech exhaust=Worky!
Comptech RSB + Any other exhaust=No worky worky!
Old Dec 6, 2005 | 04:00 PM
moda_way's Avatar
LOL
Old Dec 6, 2005 | 06:18 PM
CCColtsicehockey's Avatar
the perfect reason for to get the progress bar. thats my vote.
Old Dec 6, 2005 | 06:43 PM
narci's Avatar
Canuck
and with progress, you get poly U bushings.
Old Dec 6, 2005 | 06:47 PM
jiggaman's Avatar
I spend 2 much time here
and the progress one is adjustable
Old Dec 6, 2005 | 06:50 PM
xenonhid's Avatar
CGP Ebony
CJams did you like the 42-0 Butt whooping the seahawks did monday?
Old Dec 6, 2005 | 07:35 PM
JTso's Avatar
It has two holes on each side "meant" to be adjustable but the hole closest to the end doesn't really work. The endlink interferes with the mounting bracket.
Old Mar 1, 2006 | 02:14 AM
Alin10123's Avatar
Hmm... worked for me.
Old Mar 1, 2006 | 09:23 AM
waTSX's Avatar
Have camera, will travel
More flexibility with a small penalty in cost.
Old Mar 1, 2006 | 10:14 AM
JTso's Avatar
Could you post pics of the end link and see how close it is to the bracket?
Old Mar 1, 2006 | 10:45 AM
spyguyTSX's Avatar
so poly U bushings is the way to go....
is this better than the engergy bushings some people get with the Comptech RSB? or just the same?
Old Mar 4, 2006 | 11:27 AM
Alin10123's Avatar
Sure, i'll post them in a few. Let me get dressed first... kind of cold out there today.
Old Mar 4, 2006 | 11:30 AM
Alin10123's Avatar
Energy suspension bushings will require slight modification in order to fit. Easy though... you will just have to file some parts down or use a dremel or something. The regular energy suspension bushings are almost identical to the progress bushings except for the need for modifications. The only thing different is that when the energy suspension bushings, you can get the option of having a "zerk fitting" over the outside of the bracket, thus eliminating the need to unbolt the brackets to regrease the bushigns when they start to squeek. The Zerk fitting allows you to just reach under and give a few squirts of the grease gun.
However... in my opinion... since the progress already comes with polyurethane bushings, it's adjustable, and i will probably spend a little more money to modify and purchase the ES bushigns... i opted to go with the progress. It's not that much more money.
Old Mar 4, 2006 | 02:40 PM
SPARKIE's Avatar
I have Comptech but would go with Progress next time due to the bushing issues !
Old Mar 4, 2006 | 05:11 PM
amadeus303's Avatar
Very odd... on this board and the "other," some members talk about having to modify the ES bushings. I have the greaseable (w/ Zerk fittings) ones, and didn't have to modify them at all.
If you have any inclination to change out your exhaust down the line, get the Progress bar. Otherwise, go for the one that's cheaper - there's no difference in performance improvement. I got my Comptech bar (new) for $80, and my ES greaseable bushings for $11 and change.
Ironically, I need to sell my Comptech bar and get a Progress one since I'll be working on the I/H/C/E this summer...
Old Mar 5, 2006 | 04:48 AM
Alin10123's Avatar
here ya go Jtso.
The end of the swaybar looks like it's pretty much flush against the endlink bracket. Keep in mind that the endlink is connected on each side via a ball joint. So there's quite a bit of motion in the endlinks. Let me know if you want anymore pics.
Does everything look ok? From what i can see, the bar looks pretty flush against the endlink. But let me know if something doesn't look right. I didn't want to get too close to that area while the car was on the jackstands because if i hit the jackstand by mistake, i didn't want it to slide out.
Old Mar 5, 2006 | 10:39 AM
JTso's Avatar
Thanks for the pics. See if you can take a pic from the side where the red arrow is pointing. It's the gap between the end link and bracket.
Old Mar 5, 2006 | 10:45 AM
RMATIC09's Avatar
woah, why cant u have comptech RSB with a diff exhaust?
Old Mar 5, 2006 | 10:59 AM
JTso's Avatar
Yes, you can, as long as it's Comptech exhaust.
Old Mar 5, 2006 | 11:14 AM
RMATIC09's Avatar
no, i mean, i have a fuji exhaust, what difference does it make?
Old Mar 5, 2006 | 11:59 AM
JTso's Avatar
Different exhaust setups have different pipe bending techniques which may or may not interfere with the Comptech RSB. The Progress bar seems to have a tighter bend which reduces the chance of hitting the exhaust pipe. The Comptech exhaust is probably not the only one that works with the Comptech RSB besides the stocker. It's the only one that was reported without any clearance problems.
Old Mar 5, 2006 | 02:12 PM
Alin10123's Avatar
Jtso,
I tried to take some more pics from the angle that you pointed from. It's kind of hard because the wheel is in the way but i did the best i could. Do these look like what you were wanting?
Old Mar 5, 2006 | 06:10 PM
JTso's Avatar
Thanks Alin10123 for trying. It's a very tight spot for the shots. Let me take a closer look the next time when I'm under the car.
Old Mar 5, 2006 | 08:27 PM
Alin10123's Avatar
No problem. By the way... what did you mean by the end link interferes with the mounting bracket? According to what i see... the sway bar outer hole sits flush up against the end link. Is that what you were referring to?
thanks
Old Mar 8, 2006 | 09:59 PM
JTso's Avatar
End link pics
Here are some pics of the Progress RSB end link adjustment positions. I will reference the holes position 1 and position 2. 1 being the one closest to the end of the RSB.
Position 2: same position as stock (stiffest setting). Plenty of clearance.
Position 1: (softest setting) As you can see, there is barely any clearance between the end link and the bracket. In fact, I couldn't even slip a sheet of post-it note up there.
Old Mar 8, 2006 | 11:42 PM
Alin10123's Avatar
Jtso,
I dont think that my clearance is that tight. Is your TSX lowered? Mine's the stock height. Maybe that's why...
Think that could be it? Mine seems to not have any problems.
Old Mar 9, 2006 | 12:06 AM
JTso's Avatar
Yeah, the car is lowered. You might be fine but watch out for that. You could try slip a piece of paper up there to verify.
Old Mar 9, 2006 | 12:12 AM
Alin10123's Avatar
Actually today, i was in a hurry and took a turn quite a bit faster than normal and the body rolled a little more than i was expecting. So i just might go back under there and put her in the stiffest setting.
Old Mar 9, 2006 | 09:54 AM
Newplay1's Avatar
08 MDX with Sports
+ and lubes..
I have progress my
Old Mar 9, 2006 | 11:21 AM
Trance_Tsx's Avatar
progress
Old Mar 10, 2006 | 09:04 PM
Alin10123's Avatar
Ok... today while installing the bodykit i actually went back underneatht he car. There seems to be plenty of room. At least half an inch to an inch. So i dont think that the softer setting is a factory for a non lowered car.
Then... after the observation, i went in and i adjusted the bar the the stiffest setting. The ride doesn't feel that much different if any at all. But there was a noticeable difference in less body roll. Havne't had a change to test it out yet. But i will shortly.
Old Mar 19, 2007 | 11:29 AM
sbudianto's Avatar
4th Gear
Don't install comptech RSB if you have Greddy EVO2. Will not work!!!! I'm selling my comptech RSB.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
