Camber kit (problem?)
Old Sep 5, 2006 | 09:11 AM
llJrockll's Avatar
Rebourne
I have a question, I've had my camber kit installed about a week or two. But I've noticed that when driving my car at high speeds around 50-75 I feel the steering much more sensitive than before I installed Ingalls rear camber kit and allignment. The car tends to have a 'fish tail' effect as for example when I'm on the highway switching lanes I feel the car have a lot of body lean and hence have this 'fish tail' effect. Like I mentioned before this only tends to happen when driving at higher speeds Could this be normal, or anyone who's had this issue?
Thanks...
Old Sep 5, 2006 | 09:26 AM
moda_way's Avatar
Could also be tires. Stiffer sidewalls will grip the changes in the road differently. The only issue with the Ingalls is that the locking nut MUST BE tighten very well. One of them takes a good crows foot socket to get it tight enough. Easy thing to do... have the alignment checked again. If it is off, more than likely they didn't tighten them down.
Old Sep 5, 2006 | 09:55 AM
llJrockll's Avatar
Rebourne
tires, I'm running with 225/40/18 Nitto's. Could it possibly be because I'm running 225's oppose to a wider tire? I never had this issue before the camber kit/allignment, I'm sure that thing is tighten well enough. I guess I'll have them check the allignment again.
Old Sep 5, 2006 | 01:23 PM
moda_way's Avatar
Is it consistently over that speed rating? I ask, because excessive toe has that effect, but usually only bumps. Additionally, if the Ingalls were loose, you would more than likely get continually worsening performance from the rear and not constantly. Definitely a strange condition I've never heard of and I've had my Ingalls for more than 2 years.
Old Sep 5, 2006 | 02:07 PM
llJrockll's Avatar
Rebourne
The rear has that effect almost everytime I'm driving at the higher speeds. Although it does the same when I go over bumps. It's very Irritating and it feels unsafe. I'm just trying to figure out why this happen only at certain speed, I would assume something would be wrong if I would constanly getting that same effect regardless of how fast I'm going. Here's the sheet given to me when I had my allignment done, not sure how to read this or the specs/differences.
sorry for such a bad scan...
Old Sep 5, 2006 | 05:39 PM
xizor's Avatar
Bye TSX, hello domestic?
does your steering feel more sensitive or the car as a whole? the rear camber kit should not affect the steering of the front wheels. but if your toe out is out of wack in the back it will give that wobbly unsteady feeling like the back of the car wants to shoot one way or another.
bring your car back to the alignment shop and make sure everything is still correct, it could be possible, if they didn't tighten it correctly, that your rear toe is out of alignment
Old Sep 6, 2006 | 01:05 PM
llJrockll's Avatar
Rebourne
it doesn't really effect the steering, just the rear wheels.... like you mentioned It might be the toe that is out of wack that is causing this, it gives that wobbly feeling. I really don't feel it all the time, just at certain speeds like I mentioned before. I'll go ahead and take it to the shop.
Old Sep 18, 2006 | 11:34 AM
DAYTA's Avatar
I had the exact same issues that you're having last week when I installed my Tein SSs. On the drive back from Excelerate ( ), my car was wobbling all over the highway. I did my alignment this past weekend, and the comp said I was running about -0.90/-0.19 negative toe in the LR/RR (I think the spec range is -0.00-0.16). They adjusted my RCK to bring everything back into the factory range, and now everything's golden.
Old May 20, 2007 | 12:30 AM
afici0nad0's Avatar
after driving home tonight with a slight drizzle, i noticed that my rear was very sensitive to road conditions (grooves, ruts, etc.). in fact, it was so noticeable that the rear seemed to sway (i.e. fishtail) towards or away these road imperfections.
i have coilovers, rsb, and a rear camber kit. i just had my alignment done this morning.
when i noticed this sensitivity, my first assumption was that this was a combination of my rsb and fresh alignment.
comments? the fishtailing was very noticeable...
final alignment specs:
type = initial / final
left front
caster = +3.16 / +3.16
camber = -1.08 / -1.08
toe = 0 / 0
right front
caster = +1.96 / +1.96
camber = -0.96 / -0.96
toe = 0 / 0
left rear
camber = -1.00 / -1.04
toe = +1/16th / +1/16th
right rear
i believe rear toe-in range is 1/16+-1/16inch
Old May 20, 2007 | 09:04 AM
ebell's Avatar
I have 0 toe for all four corners.
when I didnl't I noticed the fish tailing as you described....
Also, check if your camber kits are tightly on even when you shake it pretty roughly.
Old May 21, 2007 | 09:09 PM
afici0nad0's Avatar
the camber kits are on securely.
did you mean you didn't notice the fishtailing feeling?
i'll have to clarify, this fishtailing only happened on a specific piece of road in the area @ ~60-70km/hr. i did not notice this fishtailing effect after my coilover install (was running -3 on the rear camber), only after my camber kit install and alignment.
i'm beginning to think it's a combination of the coilovers, rsb, camber kit, that induces more tramlining. this set-up makes steering much more sensitive. this is my assumption...
Old May 21, 2007 | 11:04 PM
daicacharco's Avatar
i really like the the firmness on the steering wheel though on our cars. i dont want it to be sensitive =/
Old May 22, 2007 | 12:21 AM
ebell's Avatar
as I mentioned before, fish tailing went away when I adjusted the toes to 0.
I could feel it at high speeds mainly too.
cycdaniel
Dec 17, 2019 10:58 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
james357
Feb 13, 2016 02:37 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
nuldabz
Sep 3, 2015 05:49 PM
