axis decade 18x8
axis decade 18x8
really nice wheels. but will these fit? has a 40 off-set... planning to pair up w/ 235/40/18. got neuspeed sport w/ konis.
http://www.axiswheels.com/wheels/dec...cade_front.jpg
Received 3,860 Likes
those wheels are really nice but you will be really close to being flush with the car on those wheels. I have a set of volks with a +43 offset and they are really close to being in line with the side of the car. The ideal offset i would have to say is between +45 and +52.
Bye TSX, hello domestic?
Originally Posted by xizor
exact copy of the g-games 77s. those aren't even that expensive, get the real thing. I had 18x7.5 +42 and IMO they're perfectly flush, in a 18x8 you'd want ~45mm
Those do look a lot like the G-Games 77s. However, I think the spokes on the G-Games are straight which results in a much smaller lip. I like the Axis version w/ the curved spokes and the resulting larger lip better.
But, if they only come in a +40 offset in 18x8, I would not get them as you will definitely run into rubbing issues.
I almost bought the G-Games 77s until I found out that they were approximately 30 lbs/rim!
Jewdacris!!
I have the g games 18*7.5. The lip is smaller, and there are no rivets.
Alter...you sure they weight that much? I weighed my stock rims are the g games with 18s were 2 pounds lighter.
Originally Posted by Bananaairsoft
Hi Xizor. what size tire are you running with your +42mm wheels?
Axis definitely has a history of making knockoff designs. They've previously made knockoffs of BBS, Veilside, and Work rims.
WRT the 30 lb weight, it was information provided by Discount Tire. They showed me their database of wheels they carried. It had offsets, bolt patterns, weight, etc.
I knew that the 77w was pretty light. I figured the 77s may be heavier due to it being a 10 spoke design.
thanks for all the info fellas... i really wanted to get the sidewinder 2pc but in 18's. couldn't find anyone who had them. so i figured this would be the next best thing... 19's would be nice but i really don't want 35 series tires... thanks again...
30lb though!!
I think the 77s would look great on a TSX.
Just dial 1911
1 Post
Although Discount Tire's website doesn't list the 18" version, they can order it. It's cheaper than the 19s and would probably take about 6 weeks to get.
Use all 3 Pedals at once
Jewdacris!!
Originally Posted by TSX 3Pedal
I think the ones you have are the 1-piece Sidewinders, as tires.com calls it
Yeah those would be them.
Alter...im not questioning what you say the weight is, im just curious. I think i had the stocks with wheels and tires at about 42-43 pounds and the g games and nitto neo gens at 40-41 pounds, but that was on my scale at home.
I've got the 77s (Sidewinder) in 17 and weighed them before I had the tires mounted. They were 17lb each, which is 5lb or so lighter than stock. I can't imagine the 18 inch weheels being more than 3-5lb heavier, if that.
Pimpin Ain't Easy
Ahh, the 2 piece wheels, that would make sense. Oh well they are on the car so even if they weighted 30 lbs nothing i can do about it..
In case it's not clear in this thread, I don't know the actual weight of the 18x8 77s. I've never handled them personally. I only mentioned the 30 lb figure as that was what Discount Tire showed me as the weight listed in their database. Too bad their info was wrong as it kept me from buying these rims.
Post some pics of your car. I'd really like to see how they look on a TSX. Thanks.
Jewdacris!!
http://www.cardomain.com/ride/725477
These are from last year, since this i have installed the OEM kit, and am abotu to install the H & R Springs that i have.
mrkingstonvi
02-22-2016 01:53 PM
Inspire08
10-30-2015 04:00 PM
