wtf is wrong with my cruise control?????
my cruise control does not work. it turns on for a second then shuts off for no fukking reason. sometimes it doesn't even turn on at all. the HID is telling me to change the oil soon but that has nothing to do with it does it?? wtf! has anyone seen this before? thanks.
Most often caused by the brake or clutch pedal position switches failing or being out of adjustment. Try using the top of your foot under the brake or clutch pedal to pull up when setting the cruise. If it now works you need to adjust/replace the switch. Beyond that, take it to the dealer where they can use the HDS to help track it down.
4drviper
Apr 23, 2025 07:13 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
