Windows regulator
Old Apr 21, 2011 | 02:52 AM
edward4jc's Avatar
Windows regulator
My window regulator on the driver side doesnt work. I can open the driver window but not all the other ones. I can open each window from the doors seperatly they work fine but not when I try to open them from the main driver side.
Old Apr 21, 2011 | 07:38 AM
main70072's Avatar
Maybe your driver's side power window switch assembly bad.
Old Apr 21, 2011 | 03:53 PM
edward4jc's Avatar
k thanks ill look into that..
Old Apr 21, 2011 | 05:52 PM
gbaker's Avatar
I actually have a problem with my driver's window sometimes starting to roll up very slowly from the fully down position. As it goes higher it seems to pick up speed. The downward speed seems normal. Do you think it's a problem with the regulator, or do I just need to clean the window sash tracks deep inside the door?
Old Apr 21, 2011 | 06:02 PM
friesm2000's Avatar
B A N N E D
more then likely the driver's dorr switch being fucked up...
cleaning the track some can help, but more then likely the motor on the window regulator is getting weak, and will need replacement at some point
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
