Windows Freezing!!
Windows Freezing!!
Well its winter now and my windows keep on freezing, they pretty much dont open. Does any one else have this problem? could it be a leak? and is it covered under my lease/warranty? its really getting annoying.
My windows freeze--on the INSIDE
It's not just you. My windows freeze on the outside but, even more annoyingly, on the inside. I have to leave my car outside (no garage) and every day since the winter turned cold I have to scrape ice off the INSIDE of my windows. Of course, the scraping melt, which then dampens the interior, and then the cold simply freezes it up again. I've tried using that "Damp" stuff (the white crystals that soak up moisture) in a little vented basket. I've sprayed "window freeze prevention" spray on the inside (not a good idea, I know, since this stuff is poison). Nothing helps. To be fair, this same problem happened with my old Nissan Maxima, but I'm just getting sick of having a weather system inside my car all the time.
Suzie
Suzie
gets all the crazy chicks
Happened to me for the very first time (only had the car 10 months). None of my other cars (even my '99 Civic coupe with its crappy windows) had this problem, sucks because I need to show my ID to the security guards outside work so now I'm stuck opening my door to hand it over to them.
My windows occasionally get frozen shut. The rubber seal at the bottom (on the outside) will freeze to the glass and the window won't budge. If I point the heater vent to the left of the steering wheel at it, it usually thaws out in about 10 or 15 minutes. The thing that's most annoying about it is that it screws up auto down feature on the window and it stops every couple of inches afterward. To retrain it you have you get the window open all the way and continue holding the button down for about 10 seconds. This "teaches" some component (ECU?) where the bottom of the window is.
If you're getting ice on the inside of the windows to the point that it needs to be scraped off, you're probably leaking somewhere. That shouldn't be happening.
Plus, I've had this problem with my last three cars, of different makes, two of which I purchased new, so I don't think that all three had leak issues. I think it has more do with keeping the car outside, my climate (New England), and the kinds of weather patterns we get here that make interior freezing more likely.
Suzie
The problem of windows freezing to the point where you can't roll down the window, I don't believe is a design fault. It is the weather, if you get water on the windows from rain or waterever and then overnight you get freezing temperatures the water is going to freeze.
I found using something like a credit card or gift card and running it along the bottom of the outside window edge tends to break the ice, and allows the window to function.
Mike D from Ohio
How long after starting the car do you wait before rolling down the windows? I mean, I wouldn't even try to roll them down for sometime after starting the car. Let it warm up for a while.
I warm my car up for like 20 mins or even more when its that cold out. I can't stand the cold. My car is so warm when I get in that the seats are warm without the seat heaters on. But the windows should thaw well before that point.
Sometimes when I first roll them down, I get a loud crack or settling noise from when they initially move, but they still move.
If you need the windows down that soon for ventilation purposes (like if you smoke), then try the sunroof. I don't think it freezes as easily as the windows. That might be a good substitute sometimes. I would also tilt the heat vent toward your driver's window to thaw it faster.
If you have the allweather mats the driver one lets the water run right onto the floor. Just feel the carpet under it! Check both your run channel and door seal. See if there is any flaws that will let in water. Also check to see if the drains are cloged and put a vacume hose to them. Holla back let me know what you find!
boost owns
This doesn't happen to me (04 living in Connecticut) but if it did I don't think I'd care because if it's cold enough for the windows to freeze I probably have the windows up and the heat on anyway...
xsilverhawkx
09-28-2015 06:51 PM
