Where is the Manual Tranmission drain plug?
I've read the manual and i do know where the plug to check if theres enough MT fluid and where to refill.
I can't seem to find the drain plug for it. I've read a thread that i did a search on and it says somne where in the middle of the car which makes no sense to me?
Is there even a drain plug at all or do you just jack up one side of the car to tilt the transmission for the MT fluid to drain out of the filleer/check plug?
was this the thread you were referring to?
https://acurazine.com/forums/showthr...ual+drain+plug
ya, it can be confusing.
per moda_way, you'll need to remove the underbody shield to see the drain plug.
mlody
Dec 4, 2019 02:11 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
STL TL-S
Sep 23, 2015 08:52 PM
