what the F$%@..wierd problem
MACura TSX
Ok so i just posted that intake write up on the fujita i just installed but for some ODD reason my air \ heat does not work at all......what could i have possibly messed with to cause this
MACura TSX
ok wtf.....i cant figure out whats wrong . After intake install my air / heat doesnt work or my defrosters. and i just realized today in the rain that my wipers arent working either. someone wtf!
MACura TSX
Originally Posted by poltergeist
Specifically, I'd double check ground #G302 behind the left side of the front bumper, as it's the main ground point for the wipers, blower motor etc.
how would i go about that
You can either take the bumper off or try and access it through here
Did you remove any bolts in here to install a bracket for the air filter/intake. And BTW putting the intake that low with a straight shot to the engine (no baffling) is very dangerous. It's very easy for the engine to injest water through the intake with catastophic results. Seen it happen many times.
MACura TSX
what do u mean that low?
The filter is now just in front of the wheel is it not? Because you now have a straight shot into the throttle body, if you splash or submerge the air filter in water (as in moderately deep puddle) the engine will suck water through the intake tract directly into the cylinders. Because the engine is spinning and water does not compress, something breaks or bends (usually a connecting rod).
Stock air box has baffles to keep water from making it to the engine. Usually see 1-2 Hondas with intakes like that and blown up motors around here during the rainy season...and that's in SoCal.
MACura TSX
well i just ordered a hydro shield for it , what else can i do to prevent being beaten by my parents haha
Tormented by mod choices
Originally Posted by steeveage
Wouldn't you have to pretty much submerge your CAI filter in the puddle for this to happen? From what I've read it is pretty darn impossible unless you're driving through two feet of water. Curious to hear under what conditions this happened. Thanks.
YMMV but think about it next time you think you can get across that intersection....
...and by the way 814, did you fix your inop blower/wipers.
You'll have to go hunting for a good 12-18" of standing water to hydrolock the engine with a CAI. I'm not saying it doesn't happen, but with common sense about where you drive (and park!) its 100% avoidable.
Driver/Detailer
Driver/Detailer
MACura TSX
NO! i was bringing it to a local shop that usually does all my stuff for me but its like a blizzard now and i cant drive 20 mins away with NO wipers or defrosters so hopefully tomorrow ill get this sorted out
Wtf did you check for blown fuses. Did you have any grounds disconnected wtf. Wtf did you leave any connectors unplugged. WTF!
It may take 12+ inches of standing water to submerge a "CAI" when the car is sitting still--that's a no-brainer. But think about how water might move in and out of the inner fender area when the car is in motion and you drive through ~~6 inches of water.
I've seen a 4 inch puddle splash sufficiently under an Integra that it soaked the distributor cap and stalled the engine. Granted it started up again (though the idle was a bit lumpy for a few minutes), but this illustrates that even though the distributor on the Integra was 2.5 feet off the ground, it doesn't take 2.5 feet of water to soak it.
Never underestimate water and a fast moving 3000+ lb car. If you have one of those low-slung intakes, don't take chances with puddles of standing water.
Originally Posted by aaronng
I remember it was about 12" for a standard height TSX.
We have a lot of snow melting and some pretty decent puddles. I wouldn't normally do something like hitting a puddle at 30 mph, but I didn't realize it was that deep. Entire front end got hit with water.
Not Driving, Just Posting
there's a video on the net somewhere of an AEM intake on an NSX where they take the filter and stick it in a fish take to show people what is acceptable amounts of water to go through
i believe that AEM did this to help promote there bypass valve that helps prevent hydrolocking
it's a pretty cool experiment and stupid at the same time.............a damn NSX, they could have used a civic for pete's sake
Driver/Detailer
MACura TSX
Originally Posted by drunkenbuda
Did you disco your battery before you installed your intake?
yes i did.
im pretty sure i know what the problem is.
He probably took off the ground points, mounted the intake and then replaced the ground on top of the intake's mounting arm or didn't reground it at all.
pics of rotors coming later today
where is my garage?!
1 Post
might be stupid, but on the topic of hydrolocking, have you heard of anyone with an icebox setup putting hydroshield/drycharger material on the nozzle that pulls in the air as a precautionary measure?
Just dial 1911
1 Post
Its not a problem. Just dont go driving through lakes...
Sorry to thread hijack, but relating back to the hydrolocking issue, this morning it was raining like I've never seen before. Consequently, when I was driving into work today, I had to drive through one of the biggest puddles I've ever seen that was the width of the entire road and probably 6" deep (maybe even a little more ). This means it came to just around the bottom of my front bumper.
I wasn't driving too fast (probably around 5-10MPH in 1st), but given the fact that I've got an Icebox coupled with a ~2" drop I'm a little worried about the potential of hydrolocking.
I got to work OK (probably another 2-3 miles from where I hit the puddle) and the car didn't seem to react any differently. However, does anyone know how long it could take for hydrolocking to take effect? I'm nervous that my engine will seize up in a month or so. Also, is there anything I can do to prevent any further adverse effects to my engine beyond what I've already done?
(Oh, and please no "DON'T DRIVE IN PUDDLES" responses......I had no choice since there's only one way to get to my office!)
Hydro locking is an immediate oh sh^# connecting rod bending experience. Don't worry you're fine.
hyrdolock is instant.
hydrolock means that water has lock your engine. this means that you have sucked enough water into your combustion chamber to prevent the engine from rotating.
if you hydrolocked your motor you would at a minimum bend a rod, which you would be able to feel and hear in the motor. or the rod would break completely and the motor would probably seize completely.
if the car ran without any major noises or complaints your fine.
just watch the damn puddles. I drove my dropped civic for 4 years with a CAI behind a body kit that had just a mesh grille that you could push a pencil through to prevent anything from going into the filter. I never had one issue with rain or puddles. just don't drive like an asshat in rain and you'll be fine.
OK, sorry if my post made me sound like a noob (which I suppose I am in most ways) - I certainly do know what hydrolocking means and does to your engine.
Still, I have heard of people who were able to drive their cars no problem for up to a week after hitting a puddle. Then, all of a sudden their engine seized completely, and the cause was water that got into their cylinders (i.e. hydrolocking).
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
