What Caused the Lurch and how to fix
Old Aug 16, 2008 | 12:01 PM
DiaBando's Avatar
gistered User
Pulling out this AM from a dead stop from my usual 'hot spot' for fresh produce, onto rt 22; a busy, built up 2 lane highway in NJ, I experienced a lag, a lurch of sorts that I have experienced before–when standing on the throttle–when I need to get out ahead of traffic. It was a bit disorienting to me. It was not like I was 'cutting in' on traffic, but, a maneuver that had to preformed quickly. Once I let up on the gas, the TSX took off nicely. What can I do to correct it?
Old Aug 16, 2008 | 01:15 PM
LuvMyTSX's Avatar
Yikes. You definitely don't want to mess around on Rt. 22. Need to get out there and going pretty fast. As for the lurch, I'm not sure how to fix that.
Old Aug 16, 2008 | 01:33 PM
CiViCKiDD's Avatar
gets all the crazy chicks
When I first got my TSX I dealt with the dreaded "lurch" problems. I wasn't used to DBW and had to relearn how to shift.
Are you sure you didn't just eff up the shift?
DiaBando's Avatar
gistered User
Once I'm going–I'm gone!! haha! And a 'lurch' is not that accurate a description. Its like the throttle is ahead of me–or, too much throttle for what I need at the moment. Hard to describe. Like a 'big' hesitation would be a good description.
Old Aug 16, 2008 | 03:18 PM
DiaBando's Avatar
gistered User
Don't think so. I mean, I was in gear, ready to pop the clutch. It was like this 'gush' of power (haha) then a hesitation sensation. Like I wasn't in sync with the vehicle.
Old Aug 16, 2008 | 03:46 PM
kennungesser's Avatar
Possible VSA kicking in?
Old Aug 16, 2008 | 04:27 PM
DiaBando's Avatar
gistered User
Nope. Never have it on. Ever. Happened so quickly. When The car felt under control again, in a split second, I was off and running.
Old Aug 16, 2008 | 09:51 PM
green_henry's Avatar
How's your oil level? When the oil level is low, I definitely feel it when coming off the line.
Old Aug 17, 2008 | 11:32 AM
JTso's Avatar
It's the POS DBW on our car. I don't think there's a fix without reprogramming the ECU. You may experience bucking during acceleration from a dead stop which feels like throttle on/off. IMO, it's the worst part of the TSX.
Old Aug 17, 2008 | 12:02 PM
poltergeist's Avatar
So you manually turn off the VSA every time you start the car?
Old Aug 17, 2008 | 05:16 PM
DiaBando's Avatar
gistered User
Its always of–until I accidentally hit the button on my oh-5.
Old Aug 17, 2008 | 05:20 PM
DiaBando's Avatar
gistered User
Ah! That's probably what it is. I've experienced the 'bucking' you describe, even after the hondata reflash.
Old Aug 17, 2008 | 05:22 PM
DiaBando's Avatar
gistered User
Changed it last weekend–and monitored the oil several days this week. Its fine.
Old Aug 17, 2008 | 07:42 PM
hadeze's Avatar
does it do it off the line or when you are moving and try to overtake someone. What are your rpms like?
Old Aug 18, 2008 | 12:04 AM
No it's always on unless you manually turn it off every time you start the car. It's in the owner's manual.
Sounds exactly like VSA/Traction control kicking in. Likely one (or both) of the front wheels started to slip and the VSA reduced power output to compensate
Old Aug 18, 2008 | 09:15 AM
DiaBando's Avatar
gistered User
Haha!! Wadda-ya-know! Must of not registered when I read it in 05/06! Sometimes, Dyslexia Artist's suffer I from occasionally! Thanks much!!
Old Aug 18, 2008 | 03:31 PM
Still Water's Avatar
I agree. After driving my '04 for the last four years, this is the area of greatest annoyance to me if not possibly a cause of some dangerous situations. Although it rarely happens to me now, the times it seems to raise its ugly head the most is when I hammer the throttle while the car is barely moving. I've learned to anticipate those times a little better and will "give it a little foot input" before going full bore. Instant pedal to the metal input seems to overload the DBW system for a split second producing one of those F*** Me moments. I'd really like to not have to think about it but given no available fix I've learned to live with it. I would hope that the Gen2 TSX is hesitation free.
Old Aug 18, 2008 | 03:48 PM
LukeaTron's Avatar
There have been a number of posts about this and most (including myself) seem to agree that if you ease on the throttle rather than just stomping it, the car gets moving much more reliably.
Old Aug 20, 2008 | 10:16 PM
DiaBando's Avatar
gistered User
I will endeavor to control my right foot. Thanks.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
juanrl
Sep 29, 2015 03:25 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
spoiler900
Sep 23, 2015 04:41 PM
