Weird noise after Koni STR.T installed (w/ video)
I have 4 brand new Koni STR.T (orange) structs installed but the fronts, especially the driver side, makes a weird noise.
My mechanics double checked everything and he suspects it's caused by the rubber bushings and/or the spring mounting cushion.
I've ordered:
51631-SV7-004 - rubber bushing
51686-SDA-A01 - rubber spring mounting cushion
51684-SDA-A02 - dust cover lower mounting
Hopefully they will get rid of the noise once installed.
I've ordered:
Are you lowered or on stock springs?
Did you line the front shock forks up with the notch that is on the shock? The front shocks basically have to be aligned, they can't simply be put on. If that notch isn't set in line with the opening of the shock fork, it'll essentially be sitting on top of the shock fork and while you turn the steering wheel the shock will turn as well, causing weird noise. Not sure if this is really what is going on with your car, but it is very possible.
Picture below shows outright incorrect installation.
To check, just jack the car up and look to see if that notch is sitting inside the opening for the shock fork. Depending on where that notch is, you may or may not need to compress the spring to turn the shock and line it up.
Remember, just because you take the car to a "shop" to have things installed doesn't always mean they do it right, even good mechanics can overlook certain things.
Hope that helps.
Hope that helps.
miner (07-03-2014)
So I went to an Acura dealer...
The dealer's service dept guy test drove my TSX and he believes it's "dry bushings", maybe the arms are somehow over-torqued. He suggests me to instruct my mechanic to spray lubricate the upper/lower/control arm links. If that doesn't help, loosen them first lowered the car, then tighten them.
My mechanic doesn't buy it, but he said he'll try anyway.
I doubt it is steering related. All 4 corners make weird noises now. I suspect it's either the top hats are not aligned or the springs are too soft for the structs... I don't know. It's really annoying.
Hope that helps.
Hope that helps.
Not sure what you mean? Why would the shock turn when turning the wheel? The spindle turns. The shock can never turn...even if it's fully loose in the shock fork.
Unfortunately I don't have a solution yet and I'm still quite frustrated by this. I have had multiple mechanics looked at it but so far they are out of ideas on what's really making the noise. Yes, the bushings on the arms and front sway bar are not at their best shape given their age but there's no one bushing that stands out as the offending one.
The noise appear usually during a turn or exiting a corner. I really wonder if the noise is made from the STR.T or other suspension parts... Too bad I don't have an extra set of shocks to test out my theory. I contacted Koni and sent them the link to the video but they claim it's not from their parts.
