vss wire
Old Feb 26, 2006 | 04:28 PM
matrix2db's Avatar
4th Gear
vss wire
installing eclipse nav in 05 tsx auto no nav cant find vss wire no blue white at ecu yellow red at trans not working any ideas other than speed pulse generater
Old Feb 26, 2006 | 04:46 PM
Tsx536's Avatar
Rep'n Taxbrain.com
You can't find the wire there because it doesn't exist on the non navi model. You'll need to insert your own wire into the harness.
If you 're looking at the ECU from the passenger side foot well then the harness that you need to plug it into is on the far right of the ECU. This pic is from Abram's thread
Check this thread for more info.
https://acurazine.com/forums/audio-video-electronics-navigation-22/case-missing-vss-wire-solved-288633/
Old Feb 27, 2006 | 09:38 PM
matrix2db's Avatar
4th Gear
thanks got it
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
