vss wire
You can't find the wire there because it doesn't exist on the non navi model. You'll need to insert your own wire into the harness.
If you 're looking at the ECU from the passenger side foot well then the harness that you need to plug it into is on the far right of the ECU. This pic is from Abram's thread
Check this thread for more info.
https://acurazine.com/forums/audio-video-electronics-navigation-22/case-missing-vss-wire-solved-288633/
Acura604
20
Aug 5, 2017 12:55 AM
SUPRMN84
Oct 7, 2015 09:46 PM
