VSA Warning Light comes on with no activation or (observed) problem
Has anyone else experienced their VSA warning light activating when the VSA system is not active? Three times in the last month mine has come on, and stayed on until I turn off the ignition. Then when I restart the engine the light is off. I am wondering if it is a possible failure of a sensor or maybe just the warning light itself is messed up.
Me => '04, 61K miles.
Do a search...there are many threads on this. I started one not too long ago.
There are many things it could be, but most common seems to be faulty/worn brake switch. It's like a $10 part and takes 5 min. to replace. Try that before you try any other (more expensive) options.
Check your brake system. I had the bolt that attaches my brakeline to the caliper get loose, and I lost brake fluid. Subsequently, the brake indicator came on, and after that, my VSA warning light activated.
Topped off my brake fluid and haven't had any problems since.
2005 TSX 6MT
This problem occurred on my brother's TL. One of the sensors that monitors wheel speed went bad. An OBDII code is likely stored but you may not be able to read it with a generic OBDII code reader. A device that supports extended Honda specific OBDII codes may be required.
Someone stole "My Garage"
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
