TSX Center Console Parts
Old May 29, 2010 | 02:03 AM
Jaws's Avatar
When removing the top of the center console in my 2005 TSX to install an audio adapter, I accidentally cracked one of the plastic clips that hold it into place. It's not incredibly loose, but I was curious what the part replacement would cost. I looked up the part on oemacuraparts.com (An AcuraZine sponsor), and can't figure which part I want as the diagram (below) shows everything expanded. Part 1 is obviously the entire console, which I don't need. I need the part you can pull out that contains the 6 plastic clips, the heated seat controls, and the cupholder. Perhaps this is #19 Trim Plate, if you detach I number of other pieces from it which I'm not sure is possible? Any help would be appreciated. Thanks!
Old Jun 1, 2010 | 09:57 AM
DCRS's Avatar
Correct, per the description you gave #19 is the part you are after. Are you sure you must replace the whole trim panel? Can the clip be replaced?
Old Jun 24, 2010 | 09:17 AM
chlova05's Avatar
Hey I need #6. Anybody know what that is call? And if anyone is selling it, how much?
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
DUECE_DXJ
Sep 24, 2015 04:54 PM
