Transmission issue
Old 08-03-2017, 07:02 AM
Warheadmike's Avatar
Transmission issue
I bought my TSX in January. Drove great no problems until yesterday. Driving from Palm Springs to Vegas, about an hour into my trip I stop at a light. When I pressed the gas the car didn't want to go. Pulled off. No leaks no codes or lights. So I put it back an drive and it acted fine. Drove the hour back home with no issues. Drove it 3 times since then with no issues. Any ideas what happened. Thanks
Old 08-03-2017, 08:44 AM
TexasHonda's Avatar
Check fluid level in AT. Low fluid level could cause symptom. A ATF change may be indicated also, particularly if not done since new.
good luck
Old 02-03-2020, 02:58 PM
kihon's Avatar
Ever end up finding out what your issue was?
Old 04-15-2020, 07:26 PM
Tab King's Avatar
Check fluid level, change the fluid with OEM. Do it your self ($33 bucks), take it to the dealer ($110). It’s like an oil change, just keep in mind if you’re not going to do it yourself take it to the dealer. Not Firestone or pep boys or Joes lubes. You want OEM fluid, Honda fluid should be the exact same I always use Acura Fluid for my AT. Currently at 199K on m
Old 04-16-2020, 09:16 AM
kihon's Avatar
This thread is about a TSX, not a TL. Not the same.
Bhaskar Nyshadham
03-12-2018 01:39 PM
wajo22
11-18-2017 09:36 PM
J Sun Harris
06-08-2017 01:34 PM
jblaze06
10-20-2015 10:38 AM
TheChamp531
06-25-2014 07:42 PM
Quick Reply: Transmission issue
