Time to get new calipers?
Old Jun 22, 2009 | 04:26 AM
Thecrazytrains's Avatar
So I got my car almost a year ago today, everything has been a smooth road so far, no major problems. It all started after I blew my tire on a pothole(New England streets :thumbsdowI) had to replace my brake pads in January then about a month after that I noticed my car started pulling to the left when I brake. My one friend said one of my calipers could be sticking and I was reading online that the calipers could be worn down. I was thinking about getting them checked out, but I'd rather not have to pay 50 bucks to get my brakes checked out. Btw, the reason I mentioned the blown tire is because the rim was slightly bent so Im wondering if that could be a reason to why car started pulling. Anyway, I hope someone could help me out, haven't been disapointed by acurazine results yet.
Old Jun 22, 2009 | 09:13 AM
wreak's Avatar
After you hit the large pothole and bent a rim did you ever take your car in to get a proper 4 wheel alignment done?
Old Jun 22, 2009 | 09:44 AM
Bananaskin's Avatar
wreak is correct, have u got an alignment?
Does it pull only when u break?
Old Jun 22, 2009 | 11:36 AM
sortudo7's Avatar
Site Lurker, Rare poster
+1. Also did you replace the rim? Balance out the tires to make sure they're good? Perhaps a really bad pothole messed up an axle etc. Never heard of a brake caliper causing pull.
Old Jun 22, 2009 | 01:43 PM
The tire that was slightly bent was the front right. I moved that tire to the back right when I put my pads on just so I didn't have one of my drive wheels bent. I got the car alligned again when I got my new tire put on, so I assumed that they wouldn't have put the tire on if the rim was too messed up, but I could be wrong. I may end up getting the rim rebalanced but I was either planning on getting new rims, or upgrading to a TL-S
Old Jun 26, 2009 | 10:16 AM
tjpavlov's Avatar
9th Gear
Check the Rotors
It sounds to me like you have a warped rotor. Did you buy the car new? How many miles does it have on it?
If you burned through a set of pads in your first year of owning a new car, I would bet that you also have some serious wear on the rotors. You might want to think about getting them turned (not something I generally recommend except when the car pulls).
Old Jun 28, 2009 | 03:02 AM
It's an 06 tsx. The rotors looked ok when I replaced the pads. At the moment I have 39500 on the odometer. I should probably get a new rim too.
Old Jun 28, 2009 | 09:10 AM
HoRRo's Avatar
iVTEC no koe
Jack up the front, pull the handbrake, put car in neutral, spin both tires to see if one is harder to spin than the other, to confirm if the caliper is sticking/seizing. Worst case, you could just take off the wheel, and follow the the DIY for brake pad replacement to check to see if the caliper piston moves back in.
Edit: Since you replaced the pads recently, I'm assuming you didnt notice anything strange when you did it. If that's the case, your caliper seems fine.
merc009
Oct 3, 2015 12:59 AM
forrie
Sep 15, 2015 09:57 AM
jmoney2001
Sep 11, 2015 12:07 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
nuldabz
Sep 3, 2015 05:49 PM
