Ticking engine noise
Old Nov 2, 2010 | 12:16 PM
brunnejo's Avatar
7th Gear
I have an '04 TSX. Already had the engine replaced at 120,000 miles when a timing chain tensioner failed and the engine went out of time. Replaced with an engine that had around 40,000 miles. Drives great...but about a week ago a check engine code P0420 was illuminated. Mechanic thinks it's the catalytic converter...which makes sense because I'm at 140,000 miles, and there is a rattling/chirping noise coming from the cat converter.
While I was looking around the car, also identified a ticking engine noise that can only be heard when the hood is raised. It's concerning, because I've already had engine issues once. The surpentine belt looks old...maybe a slight squeel...but the clicking is definitely coming from the engine.
Any ideas? Is the P0420 code in anyway related?
Old Nov 3, 2010 | 08:13 AM
stellarsteve90's Avatar
I'm havin the same problem rite now.....wonder if it has somethin to do with the valve clearance..hmmmm...
P.S. mine only has 81k on it...
Old Nov 3, 2010 | 02:48 PM
Simba91102's Avatar
Old Guy
I've read that both the AC compressor and/or the fuel injection can be responsible for the clicking noise. Or..... it could be valvetrain noise. As long as the car runs fine and the noise isn't too objectionable, I'd say live with it (I do!).
Old Nov 3, 2010 | 04:30 PM
It seems like it gets louder when its cold outside...
Old Nov 3, 2010 | 08:36 PM
limeybstrd's Avatar
I only notice a ticking noise with the hood open. I briefly tried to pin point the source with a stetoscope but couldnt locate it.
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
