Thump coming from rear
Old May 26, 2005 | 06:01 PM
felixthekat's Avatar
Meow.
I was driving along today when I started hearing a thumping/clunking noise from the rear. I can especially here it when making turns or going over bumps on the road. The thump can be felt through the car. I'm pretty sure its not the spare tire cause I took everything out of my trunk. I do have a comptech rear sway bar but I don't know if it is the cause of the problem. I searched for other threads and they said that their endlinks broke. But, mine seem fine. Anyone with any idea what is wrong?
Old May 26, 2005 | 06:09 PM
CJams's Avatar
Guinea Pig
Did you replace the suspension?
Old May 26, 2005 | 08:12 PM
scl23's Avatar
Goldmember
Dead body? Gotta tie them down. Sometimes my basketball rolls and thumps around in the trunk.
Old May 26, 2005 | 08:15 PM
CCColtsicehockey's Avatar
i have the same clunk and cant figure it out. i have been told many times it probably the end links but i dont know what to look for so I am going to have the dealer look at them when it goes in this coming week.
Old May 26, 2005 | 08:59 PM
ok well finally getting sick of the noise i decided i didnt care how late it was or dark out and took it apon myself to check my end links. well guess what. the passenger side endlink was loose and causeing the noise. now my suspension is whisper quite basically. i am now fully satisfied with my tein flex coilovers
Old May 26, 2005 | 10:21 PM
matelot's Avatar
what's "end link" and how you fixed it ?
Old May 27, 2005 | 01:11 AM
Meow.
Loose endlink you say? I'll check it out when I have some time. Hopefully, that's the only thing wrong. Oh, and I have a stock suspension, with a comptech rear sway bar.
Old May 27, 2005 | 01:16 AM
loxllxol's Avatar
Take a closer look. The flange of your exhaust is probably hitting the CT sway.
Old May 27, 2005 | 02:09 AM
05_TSX_GP's Avatar
Top notch 6MT
Ah... the infamous noise from the rear. First off, my ride is completely bone-stock. I've reported in various related threads that I have had some kind of clicking/ticking noise from the rear from time to time. I have checked almost everything mentioned and none of them seems to apply in my case.
The only thing I haven't checked for is loose endlinks - I have checked for broken endlinks though and they are clearly not broken.
Anyway, over the past 2+ weeks, I have noticed that I haven't heard the noise once. It seems to have just disappeared. My car is only almost 3.5 months old, I am thinking if it's just the suspension components settling in, thus the noise going away on its own?? Could that be the case guys?
Old May 27, 2005 | 02:17 AM
Meow.
If that's the case, is there any way to fix it?
Old May 29, 2005 | 08:00 AM
aaronng's Avatar
Driver/Detailer
My car was stock and I had a metal clicking/ticking noise that progressed into a full out creak when I increased my tyre pressure. Dealer found the creaking spot on the rear parcel shelf and fixed it up.
Old May 29, 2005 | 01:02 PM
05_TSX_GP's Avatar
Top notch 6MT
Thanks for sharing your experience. Where and what is the rear parcel shelf? Is it underneath the car as well just like the end-links?
About tyre pressure, how high did you increase it to? I am a bit of an avid tyre pressure watcher myself and I have been running ~34psi (measured while cold) all around.
So far the noise that has disappeared on its own is still GONE (I don't notice it's related to my tyre pressure...) So it's so far so good, but this way I'll never know what caused the noise was
Old May 29, 2005 | 11:41 PM
aaronng's Avatar
Driver/Detailer
It's part of the body, where the rear speakers are mounted to. If you open up the boot, you'll see the yellow pulltags to release the folding rear seats? That's the parcel shelf. My creak was coming from the left side, just inside lining in the area where the left boot arm goes in.
I was using 32psi (cold) when I had the ticking and clicking, and when I increased it to 36psi, it became a creak.
With mine, I can hear that it is coming from inside the cabin somewhere (very sharp and clear click). Is it the same for your clicking? Or do you feel/hear that it is from the outside?
Old May 30, 2005 | 12:24 AM
JTso's Avatar
How did the dealer fix it?
Old May 30, 2005 | 12:40 AM
Meow.
I retightened the sway bar components and now my thunk is gone. woot.
Old May 30, 2005 | 02:55 AM
drunkenbuda's Avatar
Got Phó?
Same here, but i lowerd my car tho. The noise only happen when i go over bumps on the right rear. Maybe i did not position the spring right in place with the rubber? I have to find time to fix this, its killing me!
Old May 30, 2005 | 01:03 PM
05_TSX_GP's Avatar
Top notch 6MT
OK, I'll do a visual check on that parcel shelf thing. As of now, that noise is STILL GONE on mine though... When it was around, it sounded more like it was from the inside the trunk somewhere... hmm.... so the plot thickens...
And yeah, like JTso said, how did the dealer fix it???
Old May 30, 2005 | 05:37 PM
ryanhook's Avatar
Slippy maybe...
I located another rattle in the trunk. Check the lift-over (the plastic bit against the back of the trunk, closest to the bumper that covers the latch and back wall of the trunk) and you'll see that it rattles up against the bare metal of the inside of the trunk. Anyone know what I mean?
I'm going to put some foam tape in there to see if it eliminates my rattle.
Old May 30, 2005 | 06:03 PM
05_TSX_GP's Avatar
Top notch 6MT
I'll take a look at mine and see if I can locate what to mean... maybe you can post a pic of that to help the visual too
Old Aug 9, 2005 | 12:42 PM
afici0nad0's Avatar
very informative thread.
as of late, i too have been experiencing this "trunk rattle."
i'm hoping it is only the lift-over, and not suspension-related...
Old Aug 11, 2005 | 01:45 PM
dmbfan36_23's Avatar
I found that the trunk tray kinda makes a thumping noise when going over bumps :-/.... I guess I need to bungee it down or just ignore it...
Old Aug 12, 2005 | 09:36 AM
afici0nad0's Avatar
i'm gonna have to check the end-links. it doesn't sound like it's coming from the spare tire lift-over.
i have no idea what i'm looking for. what does an end-link look like?
Old Aug 15, 2005 | 08:44 AM
afici0nad0's Avatar
ya, i think i'm hearing this "click" too.
i gotta check this parcel shelf out...
Old Aug 17, 2005 | 06:17 AM
the tray over the spare tire is not secured to the tire..I think it may bounce over bumps and makes a somewhat deep thumping noise...
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
d.lim
Sep 15, 2015 08:54 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
