Temperature Readout in the Cluster
Old Apr 18, 2004 | 07:00 PM
jkrud's Avatar
Question Temperature Readout in the Cluster
The thermometer in my TSX is usually 15 to 20 degrees off when I get in the car and it takes about 15 to 20 minutes before it reads correctly. I know it is not going to be right on at startup but isn't this excessive. Is it normal for it to be so inaccurate?
Old Apr 18, 2004 | 07:09 PM
ortiz's Avatar
Don't listen to me.
Re: Temperature Readout in the Cluster
Mine is usually off too, but only by about 10 degrees. I though it was because my grarage is always warmer that the outdoors.
Old Apr 18, 2004 | 11:14 PM
jlukja's Avatar
The manual says it won't read correctly when its parked but you should get a pretty accurate reading (+ or - 2 deg.) after driving it for a few minutes. There's a way of calibrating the readout if its off. Again, check the manual.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
