This suxs 3 days and already problems
Old May 14, 2004 | 06:14 PM
SpoonTsx's Avatar
Thumbs down This suxs 3 days and already problems
Just picked up the car on tuesday and already experienced windsheild rattles andcar pulls to the left at high speeds.
Old May 14, 2004 | 06:49 PM
slo007's Avatar
Master in Science
Re: This suxs 3 days and already problems
Both normal.
Old May 14, 2004 | 06:58 PM
SpoonTsx's Avatar
I knew what i was getting into because i checked out this forum before i purchased it, but comon...3 days??
Oh well, lets see if the dealer can fix it...
Old May 14, 2004 | 08:14 PM
CGTSX2004's Avatar
The pulling is likely due to some work having been done on the car prior to final release. Take it back to the dealer and have them look at the alignment. The windshield rattle seems to be something that is coming up sporadically. I'm sure the dealership will cover both under warranty.
Old May 15, 2004 | 01:59 AM
slo007's Avatar
Master in Science
Comes from the factory like that. Acura still has not fixed their line. Maybe they will do so for the 2005 model.
Indeed, the dealer should fix them under warranty.
Old May 15, 2004 | 09:39 AM
dabuda's Avatar
my car pulled to the left when i picked it up...dealership fixed the alignment
my indshield rattles when i'm in cold weather, last time was when i was up in NY/NJ to see family
Old May 15, 2004 | 06:20 PM
SpoonTsx's Avatar
It hasn't been cold here lately...taking the car in on Monday.
Old May 17, 2004 | 09:29 AM
kurt_bradley's Avatar
After 3 days of ownership, how many miles do you have on your car? Also take into consideration that this car is freshly assembled and is NOT BROKEN IN. Suspension bushings (that are made of rubber), interior fasteners (that are made of plastic with rubber washer bushings), and other fastening items are not entirely set into place yet. If you've ever bought a new house, it shares these types of characteristics. These items need to settle into place, as they are too new from assembly. Give it a little time before you go throwing out ideas that the car is not set correctly. Check your tire pressures, make sure you're on a straight and smoothly paved road before guessing that your alignment is out of spec. You could have a concern as simple as the balance being a little out of spec. All too often, people suspect alignment issues.
Old May 17, 2004 | 02:39 PM
SpoonTsx's Avatar
Kurt,
Before you assume this is problem that i made up. Let give you a little history of myself. I 30 yrs old, and been working on my own cars for 10 yrs now. The only time i bring in my car for service is warranty issues. I just don't trust anyone servicing my cars and the B.S. they give sometimes. My first car that i bought, 98 prelude..no issues....2000 S2000...no issues....currently own 2002 Civic Si...there where a little rattle above the passenger side which i punched and it was fixed....
I've own and worked on enough new cars to know if and how its suppose to work. Regardless if the car is new and if its settle in or not. Rattles from the windshield and alignment on a brand spanking new should not be off, but sh!t happens I know.
I just got back from the dealer, which they test drove it and claims the tapping is from the side curtains and they don't know why the alignment is off. They will have to put it on a machine to correct. If this is a normal thing, why will the dealer even bother fixing these issue? Maybe he is just making this up too?
mada51589
Jan 9, 2025 04:40 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
