Stuck in 4th gear
Old Apr 22, 2008 | 12:41 PM
Mokos23's Avatar
Stuck in 4th gear
This morning I was driving the TSX on the expressway. I noticed that when I set the cruise control and the car was driving 70-75mph, it sounded odd. Then, I switched the car to the sportshift and it was on 4th gear. So, I wanted to switch it up to 5th gear, but it refused. I was wondering why it was doing this.
After my meeting, I got back in my car for lunch and wanted to drive around and go on the highway again. This time the car was able to go to 5th gear and the car sounded fine.
Have any of you guys experienced this before and why didn't it want to go to 5th gear?
My car only has 56,685 miles on it too.
Old Apr 22, 2008 | 01:06 PM
jmathew34's Avatar
I've had this happen to me on a road trip to atlanta. I had to turn the car off and turn it back on to shift properly. It hasn't happened after that. I have about 115K miles on the car now... I never checked into it after that either...
Could be you are low on tranny fluid?
Old Apr 22, 2008 | 01:10 PM
Mokos23's Avatar
is there an indicator that shows my transmission fluid level anywhere on the dash?
Old Apr 22, 2008 | 03:08 PM
Mokos23's Avatar
I'm going to drive my car on my way home and see again if I got this problem. I wish that my 60,000 miles service can be done sooner. I guess I'll need to drive the TSX more.
Old Apr 22, 2008 | 04:23 PM
Mokos23's Avatar
Well, just got home and the car is fine, going through the 1-5th gear smoothly.
Old Apr 22, 2008 | 04:29 PM
PACman's Avatar
Was your car warmed up to normal operating temp this morning while you were on the hwy?
Old Apr 22, 2008 | 04:40 PM
Mokos23's Avatar
hmm well, i did let it sit for a minute or so on the driveway because i had to type in directions in the navi to find this place for the meeting. so, i guess i did have it warmed up. i only noticed that something was wrong when i got the car up to 70 mph and i had put the cruise control on. the rpms normally go down to 2500 rpms around 70 and this time it was at 3500 rpms and the sound coming from the engine sounded odd.
Old Apr 22, 2008 | 04:45 PM
PACman's Avatar
Not sure about an auto tsx, but from experience with prior auto cars, the tranny would hold 4th gear until the engine is warmed up, then it would change to 5th.
Old Apr 22, 2008 | 04:48 PM
Mokos23's Avatar
well the temp gauge this morning again the needle was in the C range and it was cold, but then i remember that the needle was in the middle when i was driving in between H and C. so, i guess a freak occurance?
Old Apr 22, 2008 | 06:26 PM
jmathew34's Avatar
maybe it has something to do with the cruise control and sportshift engaged?
Old Sep 16, 2009 | 11:57 PM
Mokos23's Avatar
it did it again tonight. the car only went up to 4th gear. i didn't have cruise on and the engine yes it was cold because i left it in the train station parking lot all day, but the engine did warm up and it was still left in 4th gear. when i got home, i turned off the engine and started her up again and drove her around. i was able to see 5th gear again with sportshift.
weird.
my 04 TSX has 75,470 miles on it now.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
