Squeaky Windows!!
Old Nov 1, 2008 | 01:44 PM
CiViCKiDD's Avatar
gets all the crazy chicks
Squeaky Windows!!
I found several threads on this, but couldn't really get any firm details. My 08 TSX has had randomly squeaking windows when I pull them down, it's been doing it since new (has 8k miles on it now) and I've taken it to the dealer twice. The first time was for the front passenger window, they said they replaced some molding and the problem seemed fine for a few days, then it came back. After my drivers side started making the noise I decided to take it into the dealership last week...
...their response? They didn't hear anything, but if it squeals that's part of the car's behavior and nothing can be done. IMHO that's a pathetic answer, I didn't spend over $30k for a car that has defective effing windows. Can you guys that had this problem tell me how you got it resolved, and what the TSB numbers are (I couldn't find this).
I need to find a better dealership here in NJ....
Old Nov 1, 2008 | 02:27 PM
MMsTSX's Avatar
JDM Addict
hello.
well, the problem maybe because of rubber.
this is a total guess.
if I were you, having been to the dealer with no fix available, I would
go ahead and do the following to see if it works:
get a can of silicone spray lubricant.
roll the window all the way up.
put your finger on the window down button, getting ready.
quickly spray a small amount of silicone along the
bottom of the window, all the way across.
then quickly roll the window down. wait a few seconds (5).
then roll the window back up.
repeat no more than two times per window.
this is a complete guess, I would do it on a whim and pray it works.
you can try opening up the door panel.
then conditioning all of the rubber and plastic that touches the window
with the silicone spray lubricant. but not too much at all, not enough
to leave extra that would get all over the window. just enough to get the
rubber or whatever so it's not all dried out anymore.
complete guess really, but maybe worth a try.
Old Nov 7, 2008 | 02:27 PM
JB08's Avatar
I had the same problem on my '08 with barely 6,000Km's on it. Took it to the dealer during regular maintenance and they fixed it no questions asked. I believe I read some where that this is a known problem. Sounds like you are getting very bad service and maybe it is time to try another dealer.
Old Nov 7, 2008 | 10:01 PM
curls's Avatar
Someone stole "My Garage"
Originally Posted by MMsTSX
hello.
This is EXACTLY what I did about a month ago when my drivers' window was squeaking like a mo'fo. I called a few tint shops, looking for moleskin, and two said "I am not selling it to you because you can DIY a fix in 5 seconds -- silicone spray".
I had some at home (this stuff is magic for anything), and it worked 100%.
Old Nov 23, 2008 | 10:02 AM
007Acura's Avatar
I had this same problem on both front windows
i took it to the dealer and they used the TSB from the TL (Replace window alternator and tubing)
Problem Fixed!
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
