So I'm burning MAD oil....
Make a hole, coming thru!
[p. 234, 2007 OM] Generally, warm up the engine (2-5 minutes, so yes a short drive), turn off, let sit a few minutes, then measure while sitting on level ground. So if you go to the store for Doritos and salsa, when you come back out with the goods, check oil. Easy. If you check when it's cold, likely you're getting a high reading. Warm the engine and sling the stuff up and around inside for a while first.
They'll probably tell you to "take it easy" for the first 600mi/1000km, as per the manual. It is, however, a hotly-debated topic on almost every car forum I've been on, whether to baby the engine for the first 600mi, or to drive it hard (but after warming it up properly) in a systematic fashion, to really break-in the engine similar to many race bikes do.
I don't want to get into it and clutter your thread -- there are a few other threads regarding this on here, but my method was the systematically-hard break-in one, and I've yet to notice even a minute amount of oil being burned with the new shortblock 40,000km later. IMO, it works, and works well.
Dmassott: Can you tell us the last 5 digits of your VIN? Might follow a trend we've seen that the ones burning the oil are all very, very low on the VIN list. Although this pertained to Canadian VIN's, which may or may not be in the same sequence as the US ones. IE: My vin ends in 00032, meaning the 32nd TSX off the line (or thereabouts). However, this might be the 32nd Canadian one, or, the 32nd TSX in general. Nobody I've seen knows the answer to this, but its interesting to see if your car was one of the earliest production ones as well.
its 000142, so i guess im pretty early huh?
curls: on a side note, can you send me some pics of your car with the htch suspension setup? thanks!
FAQs to the rescue!
Actually, the 12th to 17th digits are the sequence number. The 11th is the assembly plant, mine is C, and I suspect most of ours are the same...? (Mine is C011626; I almost bought a C003888 2006 with 17,000 miles. Guess they produced a lot that year?)
FAQs to the rescue!
If they don't plan to produce > 99,999 of them, then the most significant digit could indicate destination. Sure, I'll buy that (for a dollar).
I'm trying to remember where I read the plant that the letters in the VIN indicated ... oh, found a site with this for model years up to 1998:
And here's a page from the 2007 service manual(?).
You can also punch your VIN in here => www.daijekbok.com/vindecode.asp
I found nothing referring to the 12th digit as a country of destination,so I'm curious where you found that.
11th POSITION ASSEMBLY PLANT
A = Marysville, Ohio, USA
C = Sayama, Japan
H = Alliston, Canada
L = East Liberty, USA
S = Suzuka, Japan
T = Tochigi, Japan
C = Sayama, Japan
S = Suzuka, Japan
T = Tochigi, Japan
CL9 ABP
Thanks davidspalding
I normally check my oil after resting at the gas station on long drives, or random nice days after a short drive. Was trying figure when people usually check if incase if i was getting the wrong readings.
I missed the edit window, but the details are in the Helm's service manual (mine is in the garage and I'm too lazy to go check it right now). Someone did find it way back in 2003:
https://acurazine.com/forums/1g-tsx-2004-2008-124/disseminating-tsx-vin-645343/
oh and they were lookin at the new clutch today and the effin throw bearing is cracked. so now i gotta go bitch at the place i got it and i gotta pay $50 for a new one from parts so that thy can put it in tonight.
Nice!! I wish my advisor or his manager or his managers' manager would have taken pics. Always interesting. But before I even drove more than 5 miles, I had stopped, taken a spark plug out, checked that the cylinders were shiny clean, and inspected the exterior of the block as well. Just to be triple-sure that it was a new block (it obviously was).
Any ETA on when it'll be finished?
If there is ANY way you could get them to give you some idea of WHY the old block was burning oil, please relay the information. Specs on cylinder bore (oval instead of perfectly round) would be really interesting, as I can't really see any other way that a full ring and valve seal job would still burn oil (my case, likely would have been the same in your case as well).
It's doubtful they'll run these tests at the dealership, as usually Honda North America would do so, but if they could, and you could relay it, you would be awesome!
And this would make up for me sending the H-Tech pics twice.
http://www.facebook.com/video/video....ubj=1600113809
the car is done!!! lol i dont knwo if the link will work, but the fuckers took my car out for a spin
that would be normal. they need to drive the car to make sure everything was installed and working properly.
now, it wouldn't be necessary if they took the car more than 5 miles, or accelerated hard to a high speed.
That is definitely NOT the way to break-in an engine. Driven hard is good, but only with proper engine braking and warm-up time, and cooling periods afterwards.
Hopefully you don't run into problems with that new engine! Glad you got it back so quickly though - that was fast!
calrow
May 3, 2017 10:21 PM
since its a new motor?
