So I'm burning MAD oil....
Old Dec 11, 2008 | 07:14 PM
dmassott's Avatar
Detail Cars in Philly in
So over the past couple oil changes ive noticed that im getting Really low on oil inbetween..so my last oil change was at 59,800 miles and i had my guy at the dealer (used the work there) write up an R.O. for my change this time to mark down the miles and such.
So last night i check the oil and its ridiculously low and the oil pressure light came on. i added 2 quarts and then went up to the dealer tonight and he almost put in another 2 quarts and we noticed that there is oil in my exhaust pipes. I'm at 62,800 miles!!
So they marked it down on the R.O. and im goin to take it agian in like 2 weeks when it gets low again and they're goin to have the acura rep come look at it and try to get me a new engine(they've done it before for an 04 tsx).
I just have to put my stock intake back on so that the rep doesnt bitch about it. He also told me it would be a good idea to put it a new clutch at the time they would do the engine cause they could just charge the hours of labor to the engine so i would just pay for the clutch.
I'll let you know how it works out and make sure you guys look out for this prob. Also i should mention that inbetween my last oil change (2000 miles) i honestly did not go above 4k rpms the whole time.
wish me luck
Cliffs: car burning ridiculous amount of oil
-could get replaced engine from acura
Old Dec 11, 2008 | 08:14 PM
curls's Avatar
Someone stole "My Garage"
That sounds exactly like my prior situation, but without the hassle and crap I went through.
https://acurazine.com/forums/1g-tsx-problems-fixes-128/rebuilt-engine-got-my-car-back-664193/
It eventually turned out in my favour -- not a single sign of burning any oil at all since then.
Old Dec 11, 2008 | 10:26 PM
dmassott's Avatar
yeah its already been done once at my dealer..and since i know everyone, they're tryin to help me out.
Old Jan 15, 2009 | 12:05 PM
dmassott's Avatar
Update! took the car in last night and oil was down to 1.5 quarts after 2k miles...So after the next 1500 miles i have to take it in and leave it with them for the waranty peoples to come look at it...
prob be without my car for alittel while
Old Jan 15, 2009 | 02:54 PM
PACman's Avatar
Anybody know off hand if our power train warranty covers oil leaks?
Old Jan 15, 2009 | 03:07 PM
LukeaTron's Avatar
IIRC from curls' terrible adventure, Honda doesn't consider it a serviceable problem until you're burning at a rate of 1 quart (or was it liter?) per 1000 miles.
Old Jan 15, 2009 | 04:49 PM
valeratj's Avatar
Unregistered User
wow, list of things for 04 models keeps growing...
Old Jan 15, 2009 | 04:57 PM
LukeaTron's Avatar
This isn't an 04 specific problem.
Old Jan 15, 2009 | 05:42 PM
valeratj's Avatar
Unregistered User
he said there was another 04 TSX that had to have engine swap. His car maybe 2nd and its also 04
Old Jan 16, 2009 | 08:43 AM
curls's Avatar
I believe the magic cutoff is 1q/600mi, or 1L/1000km. Both are basically the same.
Even if it's close but not worse than that, I'd definitely be pushing for replacement of the bottom end and a rebuild of the top end (assuming they don't just replace the entire engine incl. the head).
Old Jan 16, 2009 | 09:31 AM
dmassott's Avatar
hopefully a replacment
i'll let you know how it goes curls, i should hit 1500 miles aorund the end of the month since im driving 100 miles a day/6 days a week
Old Jan 16, 2009 | 01:46 PM
zguy95135's Avatar
Would they only replace it if you're the original owner?
Old Jan 16, 2009 | 06:27 PM
curls's Avatar
I'm not the original owner (bought it w/ 71,000km) but I'm sure that buying it from the dealership didn't hurt my chances any.
Old Jan 16, 2009 | 09:07 PM
dmassott's Avatar
why would that matter? its CPO with powertrain warranty till 100k
Old Jan 17, 2009 | 06:11 PM
zguy95135's Avatar
Ok then I will definitely talk to Acura since mine burns a large amount of oil as well...
Old Jan 27, 2009 | 10:30 AM
dmassott's Avatar
Car goes in tomorrow, i'll be rockin an MDX for a while
Old Jan 27, 2009 | 12:54 PM
onebadtsx's Avatar
Oh crap the TSX burns oil like that! Might be jumping on an Altima SE-R then. WOW.
Old Jan 27, 2009 | 01:04 PM
dmassott's Avatar
not all of them, just random ones really, most people dont have a huge problem
Old Jan 27, 2009 | 01:11 PM
onebadtsx's Avatar
Oh good to know. Not to thread hijack you can pm me an answer but when buying one how can you tell.
Old Jan 27, 2009 | 01:33 PM
LukeaTron's Avatar
It's very rare. There's nothing you're going to be able to look at for sure and know. Honestly, it's probably right in line or better than the failure rates seen in any other car. It's not even worth letting it influence your decision.
Old Jan 27, 2009 | 01:39 PM
onebadtsx's Avatar
Thanks for the input.
Old Jan 28, 2009 | 02:16 AM
DJNile's Avatar
Any word on why it was happening?
Old Jan 29, 2009 | 09:58 AM
dmassott's Avatar
i just dropped the car off last night, they called acura care today and they said to tear down the engine and then they will send someone out to look at it.
...and on a side note, i bought a new clutch last night and they said it wont cost me anything to put in cause they'll just charge it as part of the warranty work since its all already out
oh and fyi the mdx eats gas like a mofo
Old Jan 29, 2009 | 10:06 PM
curls's Avatar
If they say they are rebuilding, do yourself a huge favor and ask them specifically what they found that requires them to rebuild (rings/valve seals, etc). The reason I say this is because they did a FULL rebuild on all seals, rings, etc... any my car still burned oil.
If you need more information on my specific case, PM me and I can try to put you in touch w/ the service manager or operations manager at my dealership, either of whom might be able to send information to your dealership to save everyone time and money.
Old Jan 29, 2009 | 10:22 PM
Miamicarfan's Avatar
dmassott: are you the original owner of the car? If you are, how did you drive the car during the first 600-1000 miles? Did you drive on the highway at all during that time? Or on the city?
Old Jan 31, 2009 | 10:49 PM
dmassott's Avatar
thanks for the help,i'll keep that in mind. they are pushing for a new engine since they know me..the adjuster came out on friday and was taking pictures of the engine all torn apart. the warranty people are going to call on monday and say what they want to do.
my service manager is saying they'll prob replace the engine since they have already done it on an 04 before at my dealer.
Old Jan 31, 2009 | 10:50 PM
dmassott's Avatar
na, i got it with 35k certified.
so i dont know how the original owner drove it
Old Feb 2, 2009 | 03:07 PM
dmassott's Avatar
haha so my buddy just called me and said the warranty doesnt want to cover it cause they said it looks like it was raced because of the wheels(lol honda wheels) and the tinted tail lights and i need to call acura care too fight it.
lol so i call the number and its uncle bill's restaurant lol
anyway they said if our mechanic can repair the head (or whatever) then they'll put a new motor in in. if cant repair the heads then they'll look for a junk yard engine..so we'll lsee
Old Feb 2, 2009 | 04:38 PM
curls's Avatar
Look up the Magnusson-Moss act. You should have no problem getting this warrantied.
Fight this tooth and nail until you get a new engine, period.
Old Feb 2, 2009 | 08:30 PM
dmassott's Avatar
they were messing with me saying it wasnt warrantied. theyre goin to cover it. just depends how they want to do it
Old Feb 2, 2009 | 08:49 PM
lcrazyaznl's Avatar
CL9 ABP
Ah interesting how do you guys know that your burning a lot of oil? i'm wondering if i need check this out, my oils been dirty every oil change at 4-4500 miles The guys always say its not that bad.
Old Feb 2, 2009 | 09:30 PM
LukeaTron's Avatar
Oil gets dirty as part of it's job. There's nothing you can tell by looking at it. If you check your oil level, it's fine then drive 1000 miles and it's no longer on the dipstick, you've got problems. Just check your oil regularly if you're worried about it. If you have to add a full bottle more often than maybe 3000 miles, you've got cause for concern.
Old Feb 4, 2009 | 03:12 PM
dmassott's Avatar
clutch came in today!!
Old Feb 4, 2009 | 03:57 PM
davidspalding's Avatar
Make a hole, coming thru!
"We can tell the car's been raced because ... of tinted tail lights...." Would be funnier if you wren't looking at such a catastrophic problem (problems) on your car. Hope Acura is going to do right by you, I also bought mine CPO at ~ 35,000 miles. You're simply not supposed to need new engines and clutches at 65,000 miles IMHO.
Old Feb 4, 2009 | 06:55 PM
lcrazyaznl's Avatar
CL9 ABP
Normally I think when i check my oil level its fine above the line, Never had to add oil yet but maybe i should check the levels more often ?
When do you guys think its best to check levels?
like after a short drive?
Old Feb 4, 2009 | 06:57 PM
PACman's Avatar
When the engine is cold or relatively cool.
Old Feb 4, 2009 | 08:34 PM
dmassott's Avatar
took the clutch up tonight, and they are putting a brand new motor in!!!!!!
There is one mechanic there that is awesome, hes taking care of me. he cleaned the head out and all and now they are waiting for the new motor to come in!
Old Feb 4, 2009 | 08:52 PM
LukeaTron's Avatar
So they're installing a new short block with your old head then?
Old Feb 4, 2009 | 09:44 PM
curls's Avatar
Exactly what they did with mine - rebuilt head, new short block.
You'll likely have the "revised" (2006-2008) version of the short block like mine. Enjoy the supposed reduced pumping losses, possibly giving one or two HP gain...
Old Feb 5, 2009 | 09:38 AM
dmassott's Avatar
thats what im hoping for, its supposed to be in either tomorrow or monday(coming from california)
and the dent guy was at the dealer on tuesday and fixed my dent.
No dent, new engine, and new clutch, pretty much a NEW CAR! wooooo
