Service?
Old Dec 8, 2006 | 03:17 PM
EuRTSX's Avatar
Service?
So at 7800 miles, my Service light came on, and it was at 10% Oil Life.
I've had no free time to go and take it into service, so I put it off for 400 miles, and its at 8200 miles. I've called and made an appointment for Monday, but now it says "Service Due Now" on the display and reads 5% Service Oil Life. I'm not pushing my luck about anything am I?
Old Dec 8, 2006 | 06:11 PM
bz268's Avatar
Because Of You
Talking
And there is a little hidden credit card slot under the steering wheel. If you swipe your credit card there, the display will automatically reset itself. Make sure you don't have anything blocking the little antenna next to the left hand side mirror.
Old Dec 8, 2006 | 06:17 PM
EuRTSX's Avatar
Didn't really want a humorous answer. Just a yes or no. Thanks anyways.
Old Dec 8, 2006 | 06:53 PM
hrj's Avatar
hrj
here you go
Originally Posted by Tireguy
put key in ignition, press and hold the select/reset button turn the key to the "on" position, continue to hold the select/reset button until the light flashes and goes out(shouldn't take more then 10 seconds).
Oh yea you'll learn a lot about your car
Old Dec 8, 2006 | 06:56 PM
hrj's Avatar
hrj
if you want to reset the maintenance light :
Old Dec 8, 2006 | 07:01 PM
bz268's Avatar
Because Of You
I don't think there will be any problem.
One of my friends leased a Nissan for 2 years. He didn't change squash. No oil changed no nothing for 2 years. The Nissan had no problem at all.
Old Dec 8, 2006 | 09:51 PM
rambalu80's Avatar
NBP6MTTSX
I'm at 4850 miles and my oil life went to 5% earlier today with about 4838 miles on the odo & now i have the "service due now" message. I've scheduled to get her in for the A1 service on Monday. You're fine, but just to be safe get the service done ASAP.
Old Dec 9, 2006 | 01:37 AM
esco718's Avatar
you'll be fine....ive had it say "service over due" before and the oil wasnt even dirty when i drained it. its just giving you a very early warning.
Old Dec 9, 2006 | 10:04 AM
EuRTSX's Avatar
Thanks for the fast reply guys. She's going in for service on Monday.
Old Dec 9, 2006 | 01:34 PM
SoCaliTrojan's Avatar
Let me help you!
With so many posts in under a year, I would have thought that you already knew the answer...so what happened the last time you had to do an oil change?
There shouldn't be any trouble. The computer is careful and will want you to come in sooner than you really should come in. That way, you can't blame Acura on having an "unreliable" car.
We didn't change the oil in one of our accords for at least a year. Whenever someone would complain about the maintainance light, I'd just reset it...and I think I did it like 3 times before I got around to it (so that's at least 9000 miles). It was a commuter car that went about 44 miles a day. As of right now, it is running superbly.
Old Dec 12, 2006 | 05:55 AM
S14 n Tsx's Avatar
mmmmmm....
dong sang, you are worrying too much. Your car isn't going to break down so...plus, I stil havent taken mine for service. Its just tire rotation, oil change, break check up, and etc. Its just waste of money..
Old Dec 13, 2006 | 05:07 PM
EuRTSX's Avatar
I guess I'm a postwhore. I'm a bit nitpicky about this kind of stuff, because the first time I got the service light, I took it in right away. This is only my second time. Anyway, the car was serviced, never felt better. Thanks guys.
Old Dec 13, 2006 | 05:20 PM
jlukja's Avatar
It doesn't mean the car will stop running at 0%. It just means that your car is due for an oil change.
Old Dec 13, 2006 | 09:35 PM
Reach's Avatar
You realize it just needs an oil change, right? "A1" is oil change, "B1" is replace filters and oil change. Its highly complex algorithm just alternates them
If you don't feel like doing it yourself, just take it to jiffy lube for half price, and don't give the dealer a chance to screw something up with your car. Not to mention take 20 minutes instead of 3 hours.
Old Dec 13, 2006 | 09:52 PM
EuRTSX's Avatar
I'm not worried, it's not like I'm lazy and that I won't do them myself, but when the dealer gave me free oil changes for life, I don't think I'd spend the time to do it myself.
Old Jan 16, 2007 | 11:57 AM
b4ceen's Avatar
actually b1 is oil chage, rotate tires, and service brakes
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
