Right Rear Upper Arm/ Camber TSB
Old Nov 16, 2006 | 08:16 PM
danotto's Avatar
I took my 2004 TSX in today to have the Camber TSB performed. The TSB states to replace upper arm if the right rear camber is greater than -1.0. Right rear camber was -1.1 before and -1.3 after the arm was replaced. I don't understand what the new arm accomplished. Any experts out there???
Old Nov 16, 2006 | 09:56 PM
JTso's Avatar
What is the complete before and after alignment spec?
Old Nov 16, 2006 | 11:15 PM
danotto's Avatar
Here is the printout they gave me.
Old Nov 17, 2006 | 05:19 AM
moda_way's Avatar
Your right rear toe was out of spec., but not your camber. Anything between -1.0 and -1.5 degrees camber in the rear is within spec. The toe was the issue, so you really had no need to have the TSB performed, on an alignment.
Old Nov 17, 2006 | 07:34 AM
danotto's Avatar
That's what I was thinking. Acording to the TSB numbers I was a candidate for the new arm because my rr camber was greater than -1.0. Now with the new arm it is even further away from nominal specs. What a waste of time.
Old Nov 17, 2006 | 07:55 AM
JTso's Avatar
Notice how the rear left camber changed from -1.3 to -1.2 without any work done to the left upper control arm? Your original rear right camber was actually fine at -1.1 even without the control arm replacement. The camber setting will change slightly from a full tank of gas or a trunk full of stuffs. That's why there is an acceptable range which considers to be within spec. The front and rear toes were the problem areas.
Old Nov 17, 2006 | 11:46 AM
danotto's Avatar
Atleast I got a free alignment out of the deal.
Old Nov 17, 2006 | 02:38 PM
peter_bigblock's Avatar
C'mon, man! Row yer own.
-1.1 and -1.3 are not greater than -1.0. Sounds like the spec is -1.0 to -1.5. -0.9, for instance, is greater than -1.0. Do they really mean "greater than"?
Old Nov 17, 2006 | 02:40 PM
jlukja's Avatar
I think they mean further from 0.
Old Nov 17, 2006 | 03:28 PM
That's initially what I thought. You're probably right, just an observation.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
AZuser
Sep 17, 2015 10:15 AM
