Removing paint
Old Aug 3, 2007 | 02:52 PM
felixthekat's Avatar
Meow.
Removing paint
Hey guys. So long story short, my mom took my car out and she some how ended up scraping something that left some pretty deep scratches. There are a lot of white scrapes on it as well, but that looks like its paint residue and can be removed. I wiped a little bit of it off with a towel and was able to scratch out a some more white. Anyhow, are there any products that will help remove that paint without stripping the car's paint? Thanks guys.
Old Aug 3, 2007 | 03:00 PM
GrayTSX05's Avatar
scratch X usually does a good job, but I see some scratch that pass through the clear coat, so I think you need to repaint that
Old Aug 3, 2007 | 03:01 PM
PACman's Avatar
You can try 3M rubbing compound, but this CAN remove paint. I would leave it to the pros and try getting it buffed out.
Old Aug 3, 2007 | 03:12 PM
Meow.
I just want to remove the white paint for now so it doesnt look so hideous. Some of the cleargoat and paint has been scraped to hell, but its the white that looks worse.
Old Aug 3, 2007 | 03:19 PM
fadinglionhart's Avatar
claybar
Old Aug 3, 2007 | 05:28 PM
tf500's Avatar
TF500
Try StratchX
Old Aug 3, 2007 | 06:27 PM
CGTSX07's Avatar
meguires scratch x like everyone else mentioned. It usually does a good job. You will probably need to follow up with a professional detail though. If those are scratches you will need to take it to a body shop.
Old Aug 3, 2007 | 10:00 PM
xenonhid's Avatar
CGP Ebony
Not sure why some people still recommend Meguiar's Scratch-X??
It doesn't even do a decent job on Swirls.
Looking at that, you need to go to body shop. Looks like you've went beyond the clear coat and into the paint.
Old Aug 4, 2007 | 01:42 AM
0bLiViOuS's Avatar
it looks like the scratches on the 1/4 panel will come off easily, but the ones in the bumper still are deep and should get repainted. this being said, you could easily get out the paint part of the scratches if you have a good buffer. if scratch-x doesn't work, go to a place where you can get REAL detail products, and get the Meguiar's medium scratch remover. you could go over it very lightly with some thinner, but that would still require a little buffing.. just not as much. There are many more details to buffing it.. but the quick version is to just use a foam pad and dont hold it on the edges or you will burn through the clearcoat. One person suggested claybar, and that may work too.. it might just take a little more elbow grease. This being said, I was a professional detailer and am now a painter, if that adds any credibility to my statements.
Old Aug 4, 2007 | 01:47 AM
JDMPLUS's Avatar
maybe you want can try some scratch remover first and if it really doesn't come off then go for the body shop.
save yourself some money that way
Old Aug 4, 2007 | 03:23 AM
aaronng's Avatar
Driver/Detailer
ScratchX is not a good swirl remover, but it is a good paint cleaner. That is what he wants to do, to get the white residue off. Not to fix the scratches.
BTW, another vote for ScratchX.
Old Aug 5, 2007 | 02:23 AM
0bLiViOuS's Avatar
scratch x does work well with a good buffer.. using it by hand or with a cheap orbital doesn't do it justice
Old Aug 5, 2007 | 02:49 AM
aaronng's Avatar
Driver/Detailer
It's actually milder than Poorboys SSR1. So it doesn't do much. If it does remove swirls by a strong orbital/rotary, then it is the pad that is doing the cutting, not the compound.
mlody
Dec 4, 2019 02:11 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
spoiler900
Sep 23, 2015 04:41 PM
