remove '06 grille
Old Apr 3, 2007 | 10:19 AM
ZhenyaF's Avatar
Off roading in his
remove '06 grille
Hey guys
I am replacing my damaged grille with another oem '06 grille, but I dont know how to do it. I checked the FAQ section - and all I saw was mugen and Euro-R tips. So, any advice?
Old Apr 3, 2007 | 10:23 AM
clee109's Avatar
I Quit
you'll remove the grill the same way you would for the mugen and euro-r. Only difference is that you'll just reverse the steps you took to remove it to replace it.
Old Apr 3, 2007 | 10:36 AM
inkedup's Avatar
Alll you have to do is remove the radiator cover. Get a small flathead screwdriver and pop out all the clips, the center pops out, they are 2 pieces.
Old Apr 3, 2007 | 10:38 AM
ZhenyaF's Avatar
Off roading in his
thanks guys
Old Apr 3, 2007 | 11:58 AM
tle05's Avatar
yea the instructions should be the same
Old Apr 3, 2007 | 02:39 PM
ZhenyaF's Avatar
Off roading in his
a friend of mine (who works in a body shop) said that I have to remove the bumper, is that true?
Old Apr 3, 2007 | 02:47 PM
SeanS627's Avatar
Not Driving, Just Posting
no
you do not have to remove the bumper to swap out the grille. it makes it easer to get the lower clips back in, but doesn't need to be done
we swapped out an 06 grille a couple weeks ago on a fellow members car.......took 5 minutes tops to swap them out
Old Apr 3, 2007 | 06:48 PM
ZhenyaF's Avatar
Off roading in his
Originally Posted by SeanS627
no
would you mind giving me the walk through or the place where I may find the directions?
Old Apr 3, 2007 | 07:38 PM
inkedup's Avatar
There should be 12 clips to remove on top of the radiator cover, after popping all the clips out using a flathead screwdriver, simply slide the grill out towards you.
There is 4 clips on the bottom of the grill but I didnt even have to remove them in order to get the grill out.
Old Apr 3, 2007 | 09:37 PM
SeanS627's Avatar
it's as easy as inkedup states here
i am going to do a complete photo DIY for my 06 euroR conversion once it arrives from Japan
Old Apr 4, 2007 | 07:33 AM
ZhenyaF's Avatar
Off roading in his
thanks again guys
Old Apr 4, 2007 | 08:59 AM
Ruserious's Avatar
6MT G37
How was your original grille damaged and how much did you pay for another oem grille?
Another brooklyn tsx'er!
Old Apr 4, 2007 | 10:30 AM
ZhenyaF's Avatar
Off roading in his
I rammed a Lincoln town car (well actually it was about 3 mph, but still my fault). The grill is pushed in, I will take pics before I remove it. I purchased a used grille from someone here on the boards for $130. But it didn't come with the inside chrome piece (the middle line) and the A symbol. I'm hoping to salvage that from mine, but if I cant ill have to order it. The problem is that the whole grille comes in pieces from parts suppliers. I tried to get the assembly, but it doesn't show up on the websites, so I just got someone's used grille.
Old Apr 4, 2007 | 10:31 AM
tle05's Avatar
hopes everything turns out well !
Old Apr 4, 2007 | 10:43 AM
ZhenyaF's Avatar
Off roading in his
yea, it will. there was no damage to the Lincoln. Whereas I damaged my grille and the bumper is slightly misaligned now.
quanaman
Jan 9, 2023 07:33 PM
Acura604
2G RDX Photograph Gallery
27
Oct 8, 2020 09:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
scionxb3003
Sep 22, 2015 05:28 PM
