Radio and clock display out
Old Nov 9, 2004 | 08:23 PM
o3jeff's Avatar
I was driving into work this morning when all of a sudden the radio and clock diplay went out. None of the buttons on the radio or the radio controls on the steering wheel work. The radio is stuck on one station and all I can control is the volume.
Has anyone run into this problem? I already have a service appointment next week for the tail light recall and for them try and find a permanant fix for the creaking in the windshield.
If anyone has a solution, please let me know, it sucks just listening to one radio station.
Old Nov 9, 2004 | 08:24 PM
o3jeff's Avatar
By the way the, my climate control and shifter lights all work fine.
Old Nov 9, 2004 | 08:30 PM
CGTSX2004's Avatar
Definitely sounds like something for a service visit.
Old Nov 9, 2004 | 08:35 PM
o3jeff's Avatar
When I called the service guy to add it to the list of things to do, he said that he never ran into this problem.
Old Nov 9, 2004 | 08:36 PM
xizor's Avatar
Bye TSX, hello domestic?
search, you'll find lots of info
Old Nov 9, 2004 | 09:08 PM
o3jeff's Avatar
I did a search https://acurazine.com/forums/search.php?searchid=171539, but their problems all seem to have been all the light on the center were out.
Old Nov 10, 2004 | 06:40 AM
miner's Avatar
Check radio/clock fuses.
Old Nov 10, 2004 | 09:09 AM
SSN_FT1(SS/DV)'s Avatar
Cruise Missile Lobber
I would check the fuses first, but there is a TSB out for faulty headunits in a certain range of vins. I had my headunit not dim anymore when I turned the lights on. The dealer replaced the whole headunit. Hope this helps.
Old Nov 10, 2004 | 09:14 AM
Viking's Avatar
Quattro in.....
Sounds like your radio may have a short, it may have to be replaced.
Be sure to let us know how it goes and good luck.
Old Nov 10, 2004 | 09:25 AM
iamhomin's Avatar
04 remembrance
A lot of people have been affected by this, it is NOT an isolated problem, your dealership is probaby lying about never "seeing" those problems.
Old Nov 11, 2004 | 08:42 AM
wiz's Avatar
wiz
I had the lights go out on my head unit...everything still worked fine, but I could not tell what I was doing when I was changing stations, or setting the temperature, etc. The dealer said I was the 3rd TSX he has had that week with the same problem. They ordered me a new headunit and replaced it and all is well now.
Old Nov 11, 2004 | 09:40 AM
o3jeff...didn't realize it was you when I first posted a reply...if you have anymore questions just IM me. Be sure to take it to Schaller....they have dealt with this issue before and replaced my headunit w/o hesitation.
Old Nov 12, 2004 | 02:22 PM
LurchRSX's Avatar
happened to me yesterday.......f'ing bs !!!
Old Nov 12, 2004 | 02:23 PM
elduderino's Avatar
VP Electricity
I was looking in the service manual for something else and this issue was actually mentioned - I didn't read it but at least it's addressed specifically. I believe it's compononet failure.
Old Nov 12, 2004 | 02:27 PM
LurchRSX's Avatar
so they say they have to replace it.......but they need me to come...test it....order the part..then come back......
BS just order the damn thing
Old Nov 12, 2004 | 02:54 PM
slo007's Avatar
Master in Science
Old Nov 13, 2004 | 06:46 AM
o3jeff's Avatar
They are giving me a loaner car on Tuesday for this problem and some other things, I am not going to pick up my car until it is all complete. So if they have to order a radio, they will be short the loaner.
Old Nov 13, 2004 | 04:40 PM
jonnerd154's Avatar
Computer Nerd
I had the same problem, it is the radio power supply that need replacing. I think there is a TSB out on this too.
Old Nov 14, 2004 | 12:45 AM
Tsex on 19s's Avatar
Holla Back Youngin
Take it to the dealership.. let them know the situation.. they probably are aware that some tsx's are having this problem.. i had the same problem and just got my radio installed and its now perfect... only bad thing is that it took way to long for them to get the part, about 4 weeks... but im sure your dealership shouldnt have a problem.. mines lost my main contact number..
Holla Back Youngin
Oh and good luck
Old Nov 16, 2004 | 03:38 PM
Weck's Avatar
That blowed up real good!
The dealer has to pull the radio unit to get a serial number in order to get a replacement radio. I know because I'm experiencing it first hand as we speak.
Old Nov 17, 2004 | 07:01 AM
miner's Avatar
Isn't the serial number on your radio code card?
Old Nov 19, 2004 | 06:17 PM
o3jeff's Avatar
To update you guys, the radio did have a short in it and had to be replaced.
dirleton
Aug 6, 2024 08:19 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
2Quik
Sep 23, 2015 01:03 PM
