Problem with AUX input on 2006
Old Nov 27, 2005 | 03:10 AM
sun's Avatar
sun
Hello,
We just bought a 2006 last night. We tried the AUX input using an IPOD and the quality was horrible. On a previous car, we used a Kenwood deck with an AUX input and it worked great on that car. The quality is as bad as using a tape adapter. Has anyone else experienced this? We think it may be the cable, but the cable is relatively new.
Thanks,
Sun
Old Nov 27, 2005 | 05:31 AM
hans007's Avatar
it might just be a bad cable. i know this isnt the same thing, but on some computer you can wire up jacks to the front of a computer case which is more or less an aux jack. some computer has crappy aux outputs or the cables are cheap and you get static through it but the normal outputs are great.
seeing as you just bought it make your dealer handle it.
Old Nov 27, 2005 | 09:52 AM
ninjamyst's Avatar
Please keep us up to date with the quality of the Aux input (whether it is due to the cable or the aux input). The Aux is one of the feature I am most looking forward to! I also have an Ipod.
Old Nov 27, 2005 | 11:54 AM
Runt888's Avatar
Are you using the headphone jack on the iPod? If so, you want the volume to be around 75%. You will also get a lot better quality if you use the line out on the iPod instead of the headphone jack. I recommend the PocketDock. I have an AUX input on my car, and the sound is noticeably better when I use the line out.
It could also be that Acura used an improperly shielded cable, and it's picking up interference from somewhere.
Kelly
Old Nov 27, 2005 | 12:39 PM
sun's Avatar
sun
Thanks for the suggestions. We are using the headphone jack with the volume turned up all the way. This is the way we used it before. We will try a different cable and see if that helps. I will update the thread later tonight.
Old Nov 27, 2005 | 12:43 PM
Tsx536's Avatar
Rep'n Taxbrain.com
When you say the quality is horrible, do you mean that it sounds like static or is it just that the volume isn't high enough?
There are things you can get to boost teh volume.
Old Nov 27, 2005 | 12:49 PM
sun's Avatar
sun
It's not static. It's as if the volume is very low. It's more like a radio source vs. cd, where the voices and bass don't hit very well. You can have a cd source and have it turned very low, but the bass and vocals still sound good. I hope that makes sense.
Old Nov 27, 2005 | 12:55 PM
Runt888's Avatar
If it's not static, I would definately try the line out option. You can test it with a regular dock if you have one. If you want to stick with the headphone jack, you should also check the EQ settings on the iPod. You will get the best results with it turned off.
Kelly
Old Nov 27, 2005 | 01:20 PM
sun's Avatar
sun
Ok, false alarm. I'm not sure if the first time we didn't have the cable plugged all the way in or what, but I just tested it again and it is working fine in the garage. We also tried it with a dock using the line out and it sounds the same. Can't wait for the Ipod integrator.
Thanks again, this looks to be a really great community.
Old Nov 27, 2005 | 02:01 PM
feliz's Avatar
Yup, the iPod works great with my aux input.
Old Nov 27, 2005 | 04:18 PM
helraiser's Avatar
feliz, post pics of your ride!!!
Old Dec 27, 2005 | 01:19 PM
KunalPatel87's Avatar
TEMPLE OWLS Don't Sleep
Do you still have to turn the iPod volume down to 75% when using it now? Or do you use it at full volume since you have it plugged in the right way now?
Hope your enjoying your car!!!
Old Dec 27, 2005 | 07:45 PM
Colin's Avatar
If you're using the bottom iPod connector, it bypasses the pre-amp in the iPod. The volume will have no effect on the output.
Old Jan 9, 2006 | 08:02 PM
frescagod's Avatar
2010 6MT non-tech
but if you're going through the headphone jack and the volume is at 100%, it's gonna sound crappy and distorted. i would keep it around 50-75% and putz with the volume on the headunit from there.
Mr.Tea
Sep 14, 2015 09:58 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
