Power windows wont work
Old Dec 18, 2009 | 08:52 AM
ggarding's Avatar
SoCalTSX
Does anyone know why the power windows wont work. Only drivers side works.. checked fuses and all O.K.
Thank you
Old Dec 18, 2009 | 10:43 AM
poltergeist's Avatar
Did you check the lockout button on the L/F Master window switch?
Old Dec 18, 2009 | 01:33 PM
ggarding's Avatar
SoCalTSX
Yes it is not the problem. where the fuses go the reading says no power all otherfuses in car work.
Old Dec 18, 2009 | 07:11 PM
The three fuses for the L/R, R/R and R/F windows are energized by a relay in the underdash fuse box. That'd be the next thing to check.
Old Jan 13, 2010 | 02:42 AM
Thecrazytrains's Avatar
Had this exact thing happen two months ago. Mine was under warranty but I believe it was the master switch that needed to be replaced. I left it at my local acura dealer for two days and they fixed it.
Old Jan 13, 2010 | 09:14 AM
Nogard13's Avatar
Weird. If you're still under warranty, take it in and have them look at it. It's probably the switch that went bad.
Old Jan 16, 2010 | 05:43 PM
IDOSEO's Avatar
This happened to me when I had my tints put on. They found out after they took my door apart that it was actually a switch that was laying at the bottom of the door. They advised who ever worked on the car did not install the switch back and it seemed rigged.
The last time that I had my door off was when I went to the dealership and had them replace my weather strips because they were squeeking. So what they did so that I'd come in at a later date is put the switch at the bottom or barely in there so that it would disconnect the wires.
Never going back to the dealership.
Old Jan 16, 2010 | 10:12 PM
Yea thats exactly what happened with me too. I think it had something to do with them putting in the stealths for the tints so they don't get scratched up and thats when it stopped working
Old Jan 21, 2010 | 12:57 PM
Dpak's Avatar
Loading...
My rear driver side window button spring popped out of the button itself.... there was like a 2mm hole where I saw this metal thing sticking out.. I was so confused and kinda pissed... turned out it was the spring and the window doesnt work... Needed a new power alternator I believe... maybe you could check that? Bit pricey.
Old Jun 25, 2011 | 04:30 PM
jayBoy4o1's Avatar
i am experiencing this problem just now, only driver side window works, passenger and both rear does not i checked all the fuses but found nothing i can hear the relay clicking when i push the button down but nothing happens,i also try using the key fob but still nothing, i haven't done any electrical things to the car it just stop working out of no where, any advice would be great.
Old Jul 1, 2011 | 12:52 AM
jayBoy4o1's Avatar
Alright problem fixed! Brought the car to the dealer and had them take a look at it, technician said "it was the main switch,power wAs being sent to it but no power coming out" I forgot I hAD the extended warranty so it was no charge and also had the recall fixed aswell
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
k6biv
Sep 10, 2015 06:37 PM
ahsm
Sep 9, 2015 08:35 AM
dlknight
Sep 3, 2015 07:54 PM
