power outlet on?
Old Nov 26, 2006 | 05:26 PM
indigo47's Avatar
power outlet on?
Can outlet be made to stay on to accommodate GPS plugin? Thanks
Old Nov 26, 2006 | 06:34 PM
PJS's Avatar
PJS
Not sure what exactly you're trying to achieve, but the outlet is on permanently whilst the ignition is in position II or the engine running.
Other than that, it's off when the key is removed so as not to drain the battery if you forgot to unplug whatever was in it. Makes perfect sense seeing as we humans can be a tad forgetful sometimes!
Old Nov 27, 2006 | 10:38 PM
SoCaliTrojan's Avatar
Let me help you!
Like PJS said, it's on only while your ignition is on. It's a safety feature so that you don't drain your battery in the middle of no-where.
If the TSX is anything like an accord, you might be able to tap into one of the posts in the fuse box by the dead pedal. There should be something that's on if the ignition is on, and another that's on 24/7 (ie: for your car alarm).
I actually have an idea on how to set up a keyless system up easily on my tsx, but i need a reliable power source. I too have thought about using the outlet, but I'm afraid I might drain my car if I don't drive it often enough lol
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
