Passenger door power lock not operating
Old Mar 18, 2008 | 10:11 AM
perobins's Avatar
5th Gear
Of course my car is now out of warranty and numerous problems have occurred. CD player died, rattles appearing in the dash and rear deck, squeeky door hinges and now, the power door lock won't work on the front passager door!
Acura of Hamilton fixed CD player and rattles as a good will jesture. They are awesome. Stay away from Acura on Brant, they are DICKS!
Any idea how to repair the door lock. Pics would be great.
Thanks.
Old Mar 18, 2008 | 10:44 AM
Destrejc's Avatar
I'm guessing it's probably a broken hinge. I just fixed my cousins 99 civic and he had powe locks. All it was was a broken plastic hinge. We could not buy the part by itself and had to replace the whole door handle but only cost him $60. If your not trying to spend any money, I suggest alotting a whole day by opening your door assembly and figuring it out. worse comes to worse bring it to a shop opened up and have them try to figure it out for you. (They should'nt charge you too much because you already did the labor for opening it)
Old Mar 18, 2008 | 10:59 AM
LukeaTron's Avatar
Negative. This is a frequently occurring problem with all years of the TSX and several other Honda models. It's the door lock actuator. The part is about $50 IIRC and is pretty easy to replace if you're moderately inclined in the mechanical direction. There are numerous write ups complete with pictures if you search.
Old Mar 18, 2008 | 06:28 PM
Tsx536's Avatar
Rep'n Taxbrain.com
It's the door lock actuator. I've already had 2 go out.
Old Mar 19, 2008 | 10:50 PM
Howard911s's Avatar
HOWARD911S
04 TSX here...jsut suddenly realize that my driver side door lock will not work... when i press the remote, all 3 other door lock will open and close, and when i operate the door lock from inside, all 3 other door lock will open and close just not the driver side..... does it seem like the actuator problem?
Old Mar 29, 2008 | 05:14 PM
TSXEd05's Avatar
My passenger door lock just quit working this week. I ordered a new actuator from Acuraoemparts.com for $27.00 including shipping.
Old Apr 2, 2008 | 10:30 PM
chuck04's Avatar
ugh...my front passenger door lock also went dead this morning. I can see it twitching when I hit the remote, but it doesn't pop open.
it's funny how the door locks are going dead across the country at nearly the same time. may be the same batch of faulty actuators?
Old Apr 2, 2008 | 10:58 PM
JayRoam's Avatar
^same happened to me last week. popped into my dealer after playing golf, and luckily they had an actuator in stock. I was in and out in an hour
Old Apr 3, 2008 | 12:28 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Yeah, it seems like a lot of use are all having this problem. I've already had two go out and I've replaced a couple for other members on the board. Hopefully you're still under warranty. If not, let me know if you need someone to install a new actuator, the dealer charges $250+ for labor on this install
Old Apr 3, 2008 | 06:57 PM
neo661's Avatar
yeah man. they quoted me the same thing. BASTARDS! go to oemacuraparts.com. They have good prices and you can put this part on yourself. if you search the threads here you can print out the instructions, step-by-step.
rockyboy
Aug 4, 2024 10:35 AM
aleo12
4G TL Problems & Fixes
Sep 17, 2015 03:48 PM
Dunnik
Sep 14, 2015 02:56 AM
k6biv
Sep 10, 2015 06:37 PM
hand123
Sep 10, 2015 09:29 AM
