Passenger door power lock not operating
Of course my car is now out of warranty and numerous problems have occurred. CD player died, rattles appearing in the dash and rear deck, squeeky door hinges and now, the power door lock won't work on the front passager door!
Acura of Hamilton fixed CD player and rattles as a good will jesture. They are awesome. Stay away from Acura on Brant, they are DICKS!
Any idea how to repair the door lock. Pics would be great.
Thanks.
Thanks.
I'm guessing it's probably a broken hinge. I just fixed my cousins 99 civic and he had powe locks. All it was was a broken plastic hinge. We could not buy the part by itself and had to replace the whole door handle but only cost him $60. If your not trying to spend any money, I suggest alotting a whole day by opening your door assembly and figuring it out. worse comes to worse bring it to a shop opened up and have them try to figure it out for you. (They should'nt charge you too much because you already did the labor for opening it)
Negative. This is a frequently occurring problem with all years of the TSX and several other Honda models. It's the door lock actuator. The part is about $50 IIRC and is pretty easy to replace if you're moderately inclined in the mechanical direction. There are numerous write ups complete with pictures if you search.
04 TSX here...jsut suddenly realize that my driver side door lock will not work... when i press the remote, all 3 other door lock will open and close, and when i operate the door lock from inside, all 3 other door lock will open and close just not the driver side..... does it seem like the actuator problem?
ugh...my front passenger door lock also went dead this morning. I can see it twitching when I hit the remote, but it doesn't pop open.
it's funny how the door locks are going dead across the country at nearly the same time. may be the same batch of faulty actuators?
yeah man. they quoted me the same thing. BASTARDS! go to oemacuraparts.com. They have good prices and you can put this part on yourself. if you search the threads here you can print out the instructions, step-by-step.
rockyboy
Aug 4, 2024 10:35 AM
k6biv
Sep 10, 2015 06:37 PM
It's the door lock actuator. I've already had 2 go out.
