oil change problem
Old May 20, 2009 | 12:46 PM
ck123's Avatar
oil change problem
i recently did an oil change on my car and after i checked the oil, it was kind of dirty already after driving around the block. My question is, what is the best position the car should be for all if not most of the oil to drain out? about 4 to 4.5 quarts came out when it drained.
i only jacked up the front of my car, so im thinking some of the oil was chilling on parts of the engine where it could not drain.
Old May 20, 2009 | 01:31 PM
DiaBando's Avatar
gistered User
I always change my own oil, when the engine has warmed up a bit. 4 qts + filter sounds right. Checking oil levels on flat area is important, too. Just don't do it parked on, like, Jones St, in SF.
Old May 20, 2009 | 01:34 PM
wong05tsx's Avatar
Need more room in
SF is all hills :idea:
but +1 on DiaB
ck123's Avatar
^ i think i saw your car at the presidio meet. sick ass car !!
Drove the car a mile first. My driveway is flat, however putting the car on jack stands changes all that.
Old May 20, 2009 | 04:57 PM
DiaBando's Avatar
gistered User
but +1 on DiaB
mission district, smarty-pants!
Old May 20, 2009 | 05:08 PM
DiaBando's Avatar
gistered User
All but; gravity. I use to pour an extra 1/2 quart of oil in, with filter/drain plug off. Just to push any old oil out. Put gravity should do the job. I put in a magnetic drain plug, too–for what its worth. I'll say this; you will never loose the drain plug in the old oil, flowing out!
Old May 20, 2009 | 06:34 PM
Itchytoe's Avatar
Modding newbie
Jacking up the front will get the most drained out, then check it with the car on level ground and you'll get a good reading. I generally add 5 quarts, but never checked to see how much I drained out. (Considering I check the level often, and it doesn't seem to burn any, I probably drain 5 quarts)
Old May 22, 2009 | 04:55 AM
lemonade's Avatar
Why worry, dirty on the other side means the oil is doing the job. If it get dirty way too fast may means you have a sludge built-up, just may be. Of course certain dirty old oil in the pan will make your new oil look dirty right away after pouring into it.
Seriously the 2.4 is pretty reliable given basic oil change is done properly.
Old May 22, 2009 | 06:21 PM
nbtx's Avatar
still plays with cars
Vehicle should be level or close to level - no need to turn it upside down and shake it ...
Old Jun 11, 2009 | 07:40 AM
DiaBando's Avatar
gistered User
haha... just in passing; it helps to remove the oil cap when changing out the oil. Air flowing in helps push the old oil out.
Old Jun 11, 2009 | 07:48 PM
nbtx's Avatar
Yup, or pull the dipstick.
mada51589
Jan 9, 2025 04:40 PM
Zonian22
Nov 14, 2015 01:20 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
datadr
Sep 12, 2015 09:12 PM
Zonian22
Sep 2, 2015 08:19 AM
