OEM intake part with Injen CAI
problem is exactly what the picture says.
It is an OEM part, don't know what to call it exactly, but the position where i am pointing at was broken/cut due to frequent tightening with metal bracket.
Since then, when i give a little gas push and open the hood to check, it snaps off of the Injen CAI.
i know many members performed with their own DIY of bypassing this tube and jus connected from engine to the intake with one rubber tube.
but i'm looking for this part' number, i would like to get it from the dealer or possibly online.
i checked of course, but all the online part websites for OEM tsx does not have this part....
please help me if you know,
Thanks a lot
Thanks a lot
Looks like it would be:
002 17138-RAA-A00 CHAMBER, AIR FLOW 1 2006 TSX 7.56 6.02
Click on the link to confirm. Rest of the parts are as follows:
001 15772-551-000 CLIP, BREATHER TUBE 1 2006 TSX 4.04 3.22
003 17152-RAA-A00 RUBBER, BREATHER JOINT 1 2006 TSX 1.99 1.58
004 17201-RBA-000 CASE SET, AIR CLEANER 1 2006 TSX 61.53 48.98
005 17210-RBA-000 COVER, AIR CLEANER 1 2006 TSX 53.79 42.82
006 17212-P2J-J00 RUBBER, AIR CLEANER MOUNTING 2 2006 TSX 3.17 2.52
007 17213-PV0-000 RUBBER, AIR CLEANER HOUSING MOUNTING 1 2006 TSX 2.89 2.30
008 17216-PN3-000 COLLAR, AIR CLEANER 2 2006 TSX 2.96 2.36
009 17220-RBB-A00 ELEMENT ASSY., AIR CLEANER (BLUE) 1 2006 TSX 23.72 18.88
011 17229-RTA-000 JOINT, AIR FLOW TUBE 1 2006 TSX 6.81 5.42
012 17244-P72-000 SPRING, AIR FLOW TUBE 1 2006 TSX 4.80 3.82
013 17315-RBB-A00 CLAMP, AIR FLOW (80) 1 2006 TSX 6.30 5.02
014 37880-PLC-004 SENSOR ASSY., AIR TEMPERATURE 1 2006 TSX 31.86 25.36
015 90001-P0A-000 BOLT-WASHER, SPECIAL (M6X35) 2 2006 TSX 3.65 2.90
016 90091-RAA-A00 BOLT-WASHER (5X28) 4 2006 TSX 3.34 2.66
017 91405-RAA-A00 CLIP, TUBE (D34) 2 2006 TSX 2.91 2.32
018 90700-SB0-003 CLIP, AIR BLEED TUBE 1 2006 TSX 3.90 3.10
019 17227-RTA-000 CLIP, AIR FLOW TUBE 1 2006 TSX 0.25 0.20
020 17228-RBB-A00 TUBE, AIR FLOW 1 2006 TSX 35.95 28.62
021 90005-RGA-000 BOLT, CLAMP (4X25) 1 2006 TSX 1.33 1.06
You don't even need that part (unless you are leasing). It is there for the tree hugger's association for annoying the auto industry group. I think someone on here figured a way to totally remove it and make some hoses work.
Yea, it's the Chamber! I had the same exact thing happen to me too. I bought the part for like $10.xx at Acura dealership. I have always wanted to replace the piece with the hose, but when I asked in the other threads, no one answered =(. I just wanted to know what type of hose, and what size diameter.
I can't see the pic here at work but assume it's the hose that goes from the tiny air-box thing on top of the CAI, to the valve cover area. Mine kept popping off too with the silly contraption Acura had devised. I was actually getting engine work done at the dealership and when it was done, the head tech said "oh, and I replaced that hose thing that kept falling off with a new hose of the right length". Was pretty cool about it, and all it really is is a hose thatroughly matches the inner diameter (ID) of the grey metal sleeve in the existing setup, and then a hose clamp on each end, voila.
If anyone out there has pictures of the CHAMBER being replaced by a tube, Please post it! Been searching, but can't find them!
Thanks everyone for help
I just ordered the part at the dealer, it's about 7 bucks.
I will install this before i leave michigan for winter break to NJ.
yea i had somewhat a unique problem compared to other aftermarket intake guys.
my main problem was that i kept tightening the metal bracket , ot knowing that the plastic air chamber is broken.
anyways, thanks
anyways, thanks
Just out of curiosity, what is that thing? What's the functional reason it can't just be a hose like every other car I've ever owned? I assumed it was just for blow by gas scavenging the first time I saw it. Does it do anything else?
literally what the part discription says. it's air flow chamber i guess..
it sucks up air when the engine is on obviously, ad when i give it a little hard gas push, it popped out (in my case, the part was broken).
it's been popping out for 3~4 weeks, so eh wtvr why not jus change it ...
cycdaniel
Dec 17, 2019 10:58 AM
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
sockr1
Oct 1, 2015 01:31 AM
11, 17138raaa00, 17228p0aa00, 2004, 37880plc004, 5x28, air, boltwasher, broke, chamber, element, flow, honda, replace, tsx
