No throttle response?
So today my car basically lost all power. I could press the pedal to the floor and it didn't increase revs. The check engine and vsa lights came on. The engine was still running. When in neutral I could rev the engine. I pulled over and turned it off for a bit then back on. The check engine light was still on, and I was able to make it to work, with out losing all power (the roads I was on were side roads so I didn't exceed 35mph if that matters). It was definitely odd though, I had intermittent throttle response.
I have a code reader at home, but doesn't do me any good at the moment.
Anyone have ideas on what it could be?
I recently had this happen with my 2005 TSX. I changed the Accelerator Pedal Position Sensor (~$130 from Amazon) and it cleared all of my issues and the car is much more responsive now. It was pretty much plug & play, but you end up needing to take appart a lot more than you'd think you would! Search the forums, there is a good detailed writeup for a TL which basically is the same.
Here's the part:
Here's the part:
Here's the part:
Here's the part:
rcs86
08-02-2016 06:52 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
