New tires help problem
Old Nov 20, 2005 | 12:11 AM
tsx5553's Avatar
3rd Gear
i just installed new tires new the kumho ecsta asx 225/45/17 on the stock rims and mounted and balanced them. ever since i put them on my car has been pulling to the right. so i went back and had them rebalanced and check all the tire pressure but still cant solve the problem. the guy at the shop told me that i might need a alignment?? but before with my stock tires i had no problem with my alignment and i have never heard before that i need to get wheel alignments just for changing to new tires. does he kno what hes talking about? any fix
Old Nov 20, 2005 | 02:12 AM
27_'s Avatar
27_
I've noticed with a wider, lower profile performance tire the car pulls depending on grooves, dips, imperfections, and grading (to help with water drainage) on the road. Could this be your problem?
Old Nov 20, 2005 | 07:59 AM
narci's Avatar
Canuck
I had 225-45-17 before with 245-40-17 in the rear. They are very sensitive to crowns in the road.
Other then that, when I had tne C36, quite a few people where having problems wit thier new kuhmo's in terms of balancing. Turns out most of them that had the new kuhmos had a tire that had a bubble in the sidewall.
Old Nov 20, 2005 | 10:31 AM
JTso's Avatar
Try switch the front tire to the rear and see if the problem persists.
Old Nov 20, 2005 | 11:35 AM
TSXTuner's Avatar
Conicity
This is called conicity, conical shape of the tires. Typically from
small off centeredness in the steel belts.
Try switching front tires left to right, if it's the tires, pulling should
go to the other direction.
OE tires are graded to severe uniformity limits such that the manufacturing
process will control them very closely to maintain yields.
Replacement tires will have much higher limits and less process control
and this is more likely to occur after removing the OE equipment.
Old Nov 20, 2005 | 01:47 PM
tsx5553's Avatar
3rd Gear
so i wouldnt need a wheel alignment to fix this problem.. are you guys saying this is normal?? any similar problems that guys have experienced and have this fixed.
Old Nov 20, 2005 | 02:19 PM
JTso's Avatar
It's not normal if the defective tire is causing the problem. Try switching the tires to determine if in fact a tire problem. If it is, then just take it back to where you got it from for an exchange. Also see if they have the proper equipment to peform a road force measurement and balance.
cycdaniel
Dec 17, 2019 10:58 AM
jblessing
Aug 8, 2018 09:43 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Zonian22
Nov 14, 2015 01:20 PM
PeterPort
Oct 14, 2015 06:19 AM
