05 Automatic TSX Tranny noises...a smacking noise!
Old Sep 18, 2005 | 01:05 PM
greendestiny's Avatar
My 2005 TSX is brand new, it has 600 miles on it so far and I bought it nearly 3 weeks ago. Anyways, I noticed this problem since day 1 when I took the car home but not sure if its probably just the charactersitic of automatic transmissions.
I come from a honda civic manual tranny.
So anyways, I noticed that everytime I shift from Drive to Park, the tranny will make this mediumly loud "SMACK" or "CLICK"....its pretty noticeable...and I was thinking, my mom's 00 Camry doesn't do it and its got 78K miles on hers!
I also notice this sometimes from Park back to Drive...
and yes, this IS with the car NOT moving....i'm not an idiot...
just want to ask if ANYONE with a 5AT TSX experienced this problem? or if it "IS" a problem...
thanks..
Old Sep 24, 2005 | 01:53 AM
b0nustrac's Avatar
i also have the same noise....with my 05 tsx... wondering if anyone else ahve that problem???
Old Sep 24, 2005 | 07:38 AM
lcrazyaznl's Avatar
CL9 ABP
This like every honda at and acura at. It is the parking brake resetting itself. or testing.
I have this sound all the time on my families odyessy, and my tsx makes it only on a slight incline or decline when in park to drive and vice versa.
Old Sep 27, 2005 | 01:23 PM
TSX559's Avatar
i think its normal. i have a 04 at and have that same noise too. sounds like a loud crack when i put in in park.
Old Sep 27, 2005 | 04:20 PM
CJams's Avatar
Guinea Pig
I get that noise, but not when I put it in park. My driveway is on a hill and put it in neutral and coast down every day on the way out. When I get to the bottom of the driveway I usually stop and put it in gear, but If I am not at a full stop I get a huge clunk going from nuetral to drive. Even if I am barely rolling at all. I don't get it going from putting it in park.
Maybe you guys are still rolling when you put it in park?
gogozy's Avatar
a single click or smack sound when shift between P, R, D are normal, Honda AT is a different design then most other makers.
Old Sep 27, 2005 | 06:27 PM
magnifico's Avatar
This is with windows shut and doors closed ?
Old Sep 27, 2005 | 07:28 PM
drunkenbuda's Avatar
Got Phó?
Its normal, but if you think it might be a problem, take it to the stealer.
Old Oct 5, 2005 | 01:21 PM
TSX559's Avatar
I have a 04 at and it does the same thing. When I go from D to R I hear that smack or crack sound. Then I go to park. I think its normal. The car is still smooth when driving.
Old Oct 18, 2005 | 11:23 AM
dontcare4urshyt's Avatar
My car makes absolutely no noise when switching through any gears P R N D D3 or M, windows open, or closed. Its an 05 AT 10K miles build number 16000. However It does leak water!!!
Old Nov 3, 2005 | 10:38 PM
Brandon24pdx's Avatar
Por Favor?
Mine make the clack/smack noise too, and it only has 160 miles on it. Probably just an annoying design quirk, since everyones seems to do it.
Old Nov 4, 2005 | 07:52 PM
saveth's Avatar
One of Many Users
every honda i have ever owned or driven has done this. Its annoying and also normal.
Old Nov 20, 2005 | 06:05 PM
macaddict315's Avatar
yes it is the parking break resetting. when you go from reverse or neutral to park or drive it resets itself, when u drive alot then go into reverse it does it louder...
IMO it is normal and dont worry....
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
ghuns
Sep 16, 2015 04:26 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
