my remote control for the alarm doesnt work!
Old Nov 21, 2011 | 06:02 PM
DannysTSX's Avatar
i have an 04 tsx i just bought 2 weeks ago and when i press the lock and unlock buttons of the remote nothing happens. when i turn the car off a little green key light flashes and i always have to lock it from the inside or with the key from the outside. i also replace the battery on the remote and it does the same thing, anybody had/has the same issue? and how can i fix it.
Old Nov 22, 2011 | 10:01 PM
orbitup's Avatar
They probably bought a remote and didn't bother programing it.
Try this -
REMOTE TRANSMITTER PROGRAMMING
Storing transmitter codes.
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was first input will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk lid are closed.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 seconds, aim the transmitter (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remotes will be cancelled.
Old Nov 24, 2011 | 10:55 AM
DannysTSX's Avatar
thanks a lot bro, it worked. the only door that didnt workd was the drivers door but i think its the acctuator because it never locked or unlocked on programming. but im sure thats a lot cheaper than buying a whole new alarm system.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
mazen222
Oct 27, 2015 12:01 AM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
