MT 5th - 6th
Old May 25, 2005 | 09:06 AM
raynord's Avatar
MT 5th - 6th
Does anybody else find that when they shift from 5th to 6th that the lever sometimes catches in the middle. I notice a difference between when I shift in a relaxed fashion (it sticks) versus firmer ( don't notice any sticking).
It might be that the lever is trying to spring back towards neutral as it passes through the gate pattern.
I just want to know if anybody else has experienced this or do I have a problem looming.
Old May 25, 2005 | 09:28 AM
scl23's Avatar
Goldmember
Nope. Mine only sometimes sticks from 1st to 2nd. 2->3->4->5->6 is always smooth.
Old May 25, 2005 | 10:34 AM
vwong's Avatar
n00b
You were pulling the shift level straight down, weren't you? The best (and very smooth) way is to pull the level slightly away from you while you pull it down from 5th to 6th. Don't worry about it getting into reverse because it just won't. There is a lockout mechanism for the reverse.
Old May 25, 2005 | 11:05 AM
dzuy's Avatar
Troutslap Mod-DUH-rator
none of my gears stick. i rarely ever hit the gate, only when i'm not really paying any attention at all. in fact, i cant even remember the last time i hit the gate.
i just push slightly away from me to go from 5th to 6th
the tsx tranny is really smooth and easy to drive.
Old May 25, 2005 | 09:08 PM
SPARKIE's Avatar
Mine did this also (exactly) . Remedy - Got a Comptech short shifter and this is no longer an issue. You'll love it!
Old May 25, 2005 | 09:57 PM
DaveWhyman's Avatar
I used to sometimes go into 4th by accident, I've just learned to take it easy going 6th and lift the clutch a little slower to make sure everything is alright.
Old May 25, 2005 | 10:15 PM
joerockt's Avatar
Just dial 1911
I find that when shifting from 5th to 6th its best to turn my hand outward and pull down...
Old May 30, 2005 | 10:54 AM
ClutchPerformer's Avatar
Old May 30, 2005 | 02:26 PM
05_TSX_GP's Avatar
Top notch 6MT
In the very first few days with the TSX, I was having the same problem going from 5th to 6th. Then I realized (relatively quickly) the method said above makes that shift the easiest on any MT shift I've ever done!!!
George Knighton
3G RLX (2013+)
176
Sep 16, 2016 08:26 PM
TSX 09
2G TSX Problems & Fixes
Sep 23, 2015 08:25 PM
Skirmich
Sep 15, 2015 06:41 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
mrlemonjello
Sep 1, 2015 08:52 PM
