Memorized seating positions .....
Old Oct 13, 2010 | 05:11 PM
Kap's Avatar
Kap
I know it's my fault.....
It must be old age or something.
I still cannot figure out how to get into my 06' TSX using driver 1 key.
When I exit the car I need the seat back, When I enter the car the seat should still be back but need it to move forward so I can drive it.
Can I get two setting from driver #1 key ? One that brings the seat back to allow me to exit and enter the other is to bring the seat forward once I put the key in the ignition.
I have tried every thing I can think of including reading the owners manual, putting the key to #2 position in gear out of gear you name it.
Like I said must be old age.... Any help here would be greatly apprecited !
Old Oct 13, 2010 | 08:47 PM
RA032025's Avatar
in the 24th and a half...
No second memory for key one.
If no one else is using memory 2, just make memory 2 your seat forward, driving position and memory 1 your seat way back entry/exit position. Then, open door with remote #1, seat stays back...sit down...press memory 2...to exit, press memory 1.
Note, this is likely to wear out your seat motors and rails more quickly, just a thought.
Old Oct 29, 2010 | 06:36 PM
Kap's Avatar
Kap
Boy, I've got to tell you this thing has a mind of it's own !
I'm worse off now than before......
Very frustating, cannot get it to stay programmed.
Kap
Old Nov 1, 2010 | 09:48 PM
JPSMAN's Avatar
I had some issues getting my programming to stick too; it finally took the service tech about 10 tries to get it. They were ready to start replacing components.
Old Nov 7, 2010 | 04:20 PM
Kap's Avatar
Kap
Thank You !
I thought I was going nuts.... Memorized seating position does appear to do whatever it wants.
Doesn't matter which driver key 1 or 2 it does whatever it wants at random and has no pattern of repitition.
All the other electronics including navigation work fine.
I've owned this car for over two years and I'm the only one who drives it.
I drive it every day it is a great car ! except for this one little thing.
Kap
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
